Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 05-01-2005, 16:46
O-H
FRC #0048 (Delphi E.L.I.T.E.)
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available!
Hello. This is an important announcement for all FIRST Robotics Competition teams. Please share this information with the rest of your team in a timely manner. If you think that other members of your team would also like to receive these announcements, please encourage them to sign up at http://listserv.leapit.com/cgi-bin/l...join=frcpublic.
If you would like to stop receiving these messages, please see the bottom of this message for instructions.
__________________________________________________ ____
Greetings Teams:
The Engineering Department is pleased to announce the availability of the Advance Material List for the 2005 competition. It is available on the FIRST web site at: http://www2.usfirst.org/2005comp/AdvanceBuy_r4.pdf
This list contains common materials required to build the robot or field elements for the 2005 competition that are not included in the kit provided by FIRST.
Happy Building!
Now all you speculatin'-type folk can really go to town!
Name:	AdvancedMaterialList2005 - Initial Release.gif
Unread 05-01-2005, 16:57
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Advance Material List for the 2005 Competition Now Available!
I am intrigued primarily by the quart of Sunny Summer paint (looked it up on the Behr website... it's an orangish peach), the shallow pot magnet (only one?), and the Radio Shack project enclosures. Everything else seemed like pretty standard... PVC, lumber, mounting hardware, and a square foot of Lexan. Any speculation?
<edit>
Information about the magnet from the Grainger website: "Maximum Pull 20 Pounds, Diameter 2.030 Inches, Height 0.312 Inch, Hole Diameter 0.187 Inch"
</edit>
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-01-2005, 17:00
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Could someone copy and paste the list into a post. It seems like there is a big backup on www.usfirst.org and my dialup connection isn't wanting to get it.
Thanks
<edit>
nevermind i got it now
FIRST Robotics Competition 2005 Advance Material List
Rev. 4 1/5/05
Item Material Quantity Cost/ea Ext. Cost Source
1 10 ft. x 1 1/4 in. Sch. 40 Electrical Conduit
(Grey) PVC 10 $3.29 $32.90 Home Depot
2 1 1/4 in. PVC Schedule 40 End Cap 24 $0.51 $12.24 Home Depot
3 1in. PVC Sch. 40 Coupling (1 5/8 in. OD) 1 $0.29 $0.29 Home Depot
4 3/4 in. PVC Sch. 80 pipe (or a 3/4 in. schedule 80 PVC pipe nipple) 6 in Home Depot
5 1 ft x 1 ft x 1/4 in thick polycarbonate (Lexan) 1 $8.10 $8.10 McMaster #8574K28
6 1/4 in x 4 ft. x 8 ft. Plywood or Luan 1 $10.00 $10.00 Home Depot
7 1/2 in. x 4 ft. x 8 ft. Plywood 1 $15.00 $15.00 Home Depot
8 1 in. x 3 in. x 8 ft. SPF Lumber* 1 $1.97 $1.97 Home Depot
9 2 in. x 3 in. x 8 ft. SPF Lumber* 1 $1.97 $1.97 Home Depot
10 #8 x 1 1/4 in. Flat Head Wood Screw 1/2 lb. Home Depot
11 1/4 in. x 3/4 in. Hex Head Bolt 24 $0.12 $2.88 Home Depot
12 1/4 in. Washer 24 $0.05 $1.20 Home Depot
13 1/4-20 x 5/16 in. high Threaded Tee Nut 24 $0.22 $5.34 Home Depot, McMaster #90975A025
14 2 in. OD x 1/2 ( 9/32 in. ID) Fender Washer- Steel 4 $0.20 $0.80
Fastenal- Nick- 603-647-1890 or McMaster Carr www.mcmaster.com or
Ace Hardware
15 10-24 x 1.75 Flat Head Machine Screw 2 $0.10 $0.20 Home Depot or Ace Hardware
16 10-24 Elastic Stop Nut (Nylok) 5 $0.09 $0.45 Home Depot or Ace Hardware
17 10-32 x 1.75 Socket Head Cap Screw 12 $0.47 $5.64 McMaster #91255A276
18 10-32 nut 12 $0.01 $0.10 McMaster #90480A195
19 #10 Washer 2 $0.05 $0.10 Home Depot or Ace Hardware
20 4-40 x 1/4 in. Phillips head screw 4 $0.05 $0.20 Home Depot or Ace Hardware
21 4-40 x 3/8 in. Phillips head screw 1 $0.05 $0.05 Home Depot or Ace Hardware
22 4-40 nut 2 $0.05 $0.10 Home Depot or Ace Hardware
23 #4 flat washer 4 $0.05 $0.20 Home Depot or Ace Hardware
24 Shallow Pot Magnet- General P/N 376B 1 $4.85 $4.85
Grainger Cat. # 3G901, McMaster #
5685K32
25 ANSI 35 Connecting Link 1 $0.57 0.57 McMaster #6261K191
26 3/8 in dia Bolt, 5 in. long 4 Home Depot
27 Washer for 3/8 bolt 4 Home Depot
28 3/8 Elastic Stop Nut (Nyloc) for 3/8 bolt 4 Home Depot
29 1/2 in OD, 3/8 in ID hollow rod, polycarbonate (need 16 in.) 8 ft $6.40 $6.40 McMaster #8585K12
30 Behr Premium Plus Interior Flat Wall Paint- Sunny Summer (S-G-380) 1 qt Home Depot
31 4 in. x 2 in. x 1 in. Project Box 1 $2.69 $6.40 Radio Shack #270-1802
32 Lithium Multi-Purpose Grease Hardware or Auto Store
*Note: US dimensional lumber SPF (Spruce, Pine or Fir) actual size is smaller than its name
1 in. x 3 in. is approx. 3/4 in. x 2 1/2 in.
2 in. x 3 in. is approx. 1 1/2 in. x 2 1/2 in.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 05-01-2005, 17:02
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I added emphasis to the above quote. I am on my lunch break at work and don't have time to find last year's BOM release, but did it use similar language? I'm intrigued to see what sort of "robot elements" we might be required to build.
--Madison--
...down at the Ozdust!
Unread 05-01-2005, 17:04
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
If you're curious about the paint color, go here: http://www.behr.com/behrx/colorsmart...e=sunny+summer
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 05-01-2005, 17:08
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Auto grease, a project box from radio shack, 'sunny summer' paint, a hollow polycarb rod, a magnet.
These are all items that are highly abnormal for FIRST fields, in my experience.
A little research yields that you can find the color 'Sunny Summer' by searching a javascript program by the Behr company. It appears to have the rgb value E8BA16 --- awfully ugly color, IMHO.
Also, the grease suggests moving parts. I believe the project box will be used to house whatever IR component is surely to be on the field. Perhaps a robot will have to retrieve something stuck to the magnet... What is a 'Pot' Magnet, anyhow?
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 05-01-2005, 17:11
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
"Shallow Pot Magnets are all cylindrical Alcomax permanent magnets assembled concentrically in a mild steel pot"
_
Unread 05-01-2005, 17:13
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
&quot;flock their sheep&quot;
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
8ft of polycarbonate rods? doesnt seem too familiar to me. heh. ah. what a great distraction from homework. though from most sites thats standard length.
Woburn Robotics, Class of 2005.
Unread 05-01-2005, 17:15
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Question Re: Advance Material List for the 2005 Competition Now Available!
What about the single #35 chain link?
Weird.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 05-01-2005, 17:17
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
NO casters? YAY. No moving field components?
However, this list is probably not a complete one for obvious reasons.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 05-01-2005, 17:19
O-H
Hey! That yellow color looks awfully close to our team's yellow color, you know.... That being said, I'm inclined to agree with you.
Unread 05-01-2005, 17:20
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
There aren't as many big pieces as lat year, which tells me the structure on the field is much smaller, but more complicated.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 05-01-2005, 17:21
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Urhm...
Heres what the magnet looks like
-Michael Dessingue
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
And the plot thickens...
The paint and the lith grease caught my attention immediately. Why ugly orange paint and lith grease?
We can (and will) only speculate.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 05-01-2005, 17:32
O-H
My guess? The magnet is meant to be installed on the robot. Points will be scored for capturing/docking with a magnetic field target during autonomous.
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
Fantasy FIRST suggestions for next year Joe Ross Fantasy FIRST 39 14-04-2004 01:13
New Competition in MI, Mailing List Allison K Off-Season Events 0 29-03-2004 19:53
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
