Go to Post Truly listening to the wealth of advice around you is so important. Don't work in a vacuum all season long. - OZ_341 [more]
  #46   Spotlight this post!
Unread 05-01-2005, 20:49
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
Re: **FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available!
Keep in mind that this list is deceptive because its only for a basic assembly of whatever it is that we are assembly. That may mean for instance, only one goal or only one corral (for lack of better examples) so the quantities may look strange now, but they will probably make much more sense once the game is revealed and to what extent the scoring objects are used.
Woburn Robotics, Class of 2005.
  #47   Spotlight this post!
Unread 05-01-2005, 20:53
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by andy
Also, 4-40 screws are really small, those are the size that fit through the holes in the speed controllers, I wonder what they are for.
Good luck everybody!
-Andy
It just ocurred to me, those can be for the chain link... Who knows?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #48   Spotlight this post!
Unread 05-01-2005, 20:56
shamuwong's Avatar
shamuwong shamuwong is offline
pretty little words.
AKA: Mike Wong
FRC #0469 (Las Guerillas)
shamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to behold
Look at all the PVC and Endcaps. Possible game pieces?
What's up with the single ANSI 35 connecting link?
ΜOΛΩΝ ΛΑΒΕ!
attending: great lakes regional, west michigan regional, detroit regional, the championship
  #49   Spotlight this post!
Unread 05-01-2005, 20:57
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Based on the chain, the grease, and the project box, I'm going to venture that the field is going to be more interactive this year. And what's going in the box?
I've also heard it suggested that the paint is so that the IR doesn't reflect as much.
  #50   Spotlight this post!
Unread 05-01-2005, 21:04
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
maybe the IR sensors will move around the field
  #51   Spotlight this post!
Unread 05-01-2005, 21:06
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Everyone obsessing over clues and the BOM lists seems to forget that there is a much wider range of games then ones we seem to be restricting our thought (in orders of magnitude, robot size 10^0 feet, weight, 10^2 lbs, field size, 10^1 feet, power 10^2 watts, etc.) But the BOM seems to indicate that we are still dealing wiht a similarly sized field (lots of 10 ft pipe, 4x8 plywood, and 8 foot pieces of lumber.)
Of course, there are plenty of reasons for FIRST not modifying the game significantly, but I don't think the general stuff was a given
Team 1257
  #52   Spotlight this post!
Unread 05-01-2005, 21:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think with the relatively small amount of materials (in relation to previous years) that the field will be mostly flat.
  #53   Spotlight this post!
Unread 05-01-2005, 21:34
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
I agree, I think that we will have some small complex element on the field. Whatever happens, its going to be crazy!
http://www.wcsrobotics.com
team 663
team 1493
  #54   Spotlight this post!
Unread 05-01-2005, 21:53
andy's Avatar
andy andy is offline
Alumni
FRC #1139 (Gear Grinders)
Team Role: Student
andy is a jewel in the roughandy is a jewel in the roughandy is a jewel in the rough
Send a message via AIM to andy
What startles me the most, is the SIZE of the parts not the parts themselves. I wonder if the dimensions will be different this year (smaller) because the field parts are smaller?
  #55   Spotlight this post!
Unread 05-01-2005, 22:13
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
My theory:
We're going to have a moving wall in the middle of the field the field. It will rotate on a pivot and will have clearance beneath it for shorter robots like the 2003 bar.
  #56   Spotlight this post!
Unread 05-01-2005, 22:21
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Yes this field uses substantially less material than the 2004 BOM required.
I can see the caps acting as almost a ladder rung retainer (if the pipe were penetrating wood on both ends, then capped on the outsides)
I'll bet the box will house a battery powered portable and durable beacon for field use - or have something to do with the magnet trigger
I'll bet that 12x12 lexan is a pressure plate, possibly a base as in "baseball"
and the magnet will be used in a triggering device on that plate, wired up to something that would trip a feature?
those (2) 3x? 8' long boards seem like a pedestal thats capped with the 4x8 plywood and layered with the 1/4" to brace the penetrated PVC.
One bold prediction is the lack of large field objects might mean an abundance of game pieces. Man I hope the people who said baseballs weren't right.
I think were making some sort of basket or ladder thing on top of the very low (2 1/2" high maybe) pedestal to collect said game pieces.
this clear field is also a good indicator of 6 bots at a time, to give more playing room.
Although it's safe to assume this is enough equipment for you to build test features and not necessarily full playing field objects.
I think the chain link is just to throw us off.
BTW I just happen to have a purple piece of clear film, which I looked through at the BEHR yellow sample color on the white background, and it made no difference, it just gave everything a purple hue but i still saw yellow and white and everything else
www.179swampthing.org
  #57   Spotlight this post!
Unread 05-01-2005, 23:15
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
Re: Advance Material List for the 2005 Competition Now Available!
Originally Posted by Katie Reynolds
#31
Item: 4 in. x 2 in. x 1 in. Project Box
Qty: 1
Cost: $2.69
the cost is 2.69, the paint is yellow, the glasses were purple.....could this be a sign for cooney robotics?
this field seems like it is going to be pretty complex and quite involved, i can see now why people have been saying that the fields may be smaller. my question is whether this field will make it too hard for rookie teams to work on. oh, and one more, aren't magnets generally considered to be a hazard around electronic components (eg: the controllers, etc)? it seems like an odd piece to implement.
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
  #58   Spotlight this post!
Unread 05-01-2005, 23:50
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
That's because I am an idiot. Purple light is not the opposite of yellow paint. Yellow paint reflects red and green, purple film accepts red and blue. Therefore yellow paint will not appear black through purple film, it would appear red. Green paint would be the opposite of purple film (and blue film would be the opposite of yellow paint).
Zan Hecht
  #59   Spotlight this post!
Unread 05-01-2005, 23:57
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Sunny Summer!!!!!
A color that ugly can only mean one thing ...
Inflatable Clowns!!!!!!!!!!!
(or Lavery's painting his house)
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
  #60   Spotlight this post!
Unread 06-01-2005, 00:10
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by T. Hoffman
My guess? The magnet is meant to be installed on the robot. Points will be scored for capturing/docking with a magnetic field target during autonomous.
If the magnet is meant to be installed on the robot, why aren't they including it in the Kit of Parts? Nonetheless, I still like that idea. Anything involving scoring in autonomous would be awesome.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
Fantasy FIRST suggestions for next year Joe Ross Fantasy FIRST 39 14-04-2004 01:13
New Competition in MI, Mailing List Allison K Off-Season Events 0 29-03-2004 19:53
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
