Go to Post studies have shown that postive feedback works better. Driver should get a shock until he obtains target lock, then it stops. Performance incentive :^) - KenWittlief [more]
  #61   Spotlight this post!
Unread 06-01-2005, 00:34
Eric Brummer Eric Brummer is offline
there's 95% ...
FRC #1097 (Jesuit Robotics S3E)
Eric Brummer will become famous soon enough
Send a message via AIM to Eric Brummer
Re: **FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available!
Maybe the color of the paint doesn't matter at all. FIRST talked with Behr paints and they decided on an "ugly" color most likely to be found and under used by normal painting. OK so we know FIRST is calculated enough that the color would matter.
  #62   Spotlight this post!
Unread 06-01-2005, 00:35
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
There's 100 feet of 1 1/4 in. Sch. 40 Electrical Conduit. Hmm... with all this pipe- anyone thinking of Ladder Logic?
  #63   Spotlight this post!
Unread 06-01-2005, 01:00
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Advance Material List for the 2005 Competition Now Available!
Originally Posted by Rickertsen2
The Pipe couplings indicate that the pipe will be used in lengths larger than 10ft.
EDIT::
NEvermind.... The couplings are a different size
I doubt this is the case, but it would be really cool if the magned was embedded in the floor and we had to use HAL sensors to figure out when we are over a certian point on the field.
It looks like there will be a raised platform but not a high one judging from the lack of support material. I picture the plywood supported by the 1x3s and 2x 3s layed on their side.
There will definately be something moving.
Judging by the aount of small hardware there willbe something small but complex.
I don't think the second thinner sheet of plywood will be supporting weight.
lol. the entire field is raised a few inches, and there is a pit in the middle.. "ramp down."
Joel Johnson
RAGE (173) Alumni, 1999-2003
  #64   Spotlight this post!
Unread 06-01-2005, 01:07
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
I don't think that the color being the most ugly would matter. Most of the paint at Home Depot is mixed when you go to buy it.
Eric
  #65   Spotlight this post!
Unread 06-01-2005, 01:14
Will Hanashiro Will Hanashiro is offline
GM/Kettering Mentor
FRC #0322 (F.I.R.E)
Will Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really nice
Send a message via AIM to Will Hanashiro
we're playin paintball: robot style!!!
the robots are going to be runnin around... throwin paint on eachother, and we pre-spray our robots with the grease to make sure the paint rubs off easily at the end. hehee
imagine each team havin a different color paint to use... then we'd have some wildstang colored bots drivin around
just kiddin guys.
West Michigan Regional #1 Seed
2006 GLR Motorola Quality Award
2006 WMR GM Industrial Design Award
Kettering University ME Class of 2009
  #66   Spotlight this post!
Unread 06-01-2005, 04:58
Hinkel Y.'s Avatar
Hinkel Y. Hinkel Y. is offline
FRC #0188 (Woburn Robotics)
Hinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura about
Send a message via MSN to Hinkel Y.
The paint is a flat paint, which won't reflect IR light like glossy. Last year there was a big problem with the light reflecting everywhere at competitions.
In that case, our team wants to reserve white and red paint
  #67   Spotlight this post!
Unread 06-01-2005, 08:02
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
24 PVC end caps sized for the ten pieces of conduit and and only 1 coupling? No elbows that I can see listed. I don't think we'll have much more than straight runs unless they have conduit elbows in the kit which seems unlikely.
  #68   Spotlight this post!
Unread 06-01-2005, 08:35
Carpe diem
Yeah, but by your same argument; what are the other 8 pipes connected to- nothing? I'd have to presume either many parts are in the kit or a revised field parts list is coming out.
I'm no expert in building materials but I would assume that 10ft sections of pipe are the largest that the average person can easily transport. I'm guessing they won't stay that size and the field blueprints will require teams to cut up the 10ft sections into something smaller.
  #69   Spotlight this post!
Unread 06-01-2005, 09:31
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
In addition to such strange items as the 35 ANSI chain link connector, the magnet, and the project box, I'm especially intrigued by the paint and the square foot of Lexan. As far as the paint, I'm mostly interested in the fact that only 1 quart is listed, that's a fairly small amount, I think. And this square foot of Lexan, that's smaller than the footprints of the robots (for previous years anyways). In comparison to the field (at least from 2003 and 2004) that's pretty small in size.
Oh, I just can't wait until Saturday.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
  #70   Spotlight this post!
Unread 06-01-2005, 10:07
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
One quart of paint will cover about 96 square feet, on a non-porous surface.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
  #71   Spotlight this post!
Unread 06-01-2005, 10:17
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
That square foot of lexan is going to be a base, as in baseball. Robots will have to "tag" the base magnetically, or maybe they can detect when they are on the base through a Hall Effect sensor or Reed switch.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
  #72   Spotlight this post!
Unread 06-01-2005, 10:25
What part did Dave Lavery see when he first walked into Home Depot?
  #73   Spotlight this post!
Unread 06-01-2005, 18:45
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
A few thoughts:
Has FIRST ever thrown in "decoy" parts like some people are hypothesizing? It doesn't sound like it would be a terribly intelligent idea to just throw away money like that for the sole purpose of deceiving us...
Perhaps there is more to the necessary parts that has yet to be revealed? Maybe one robot will have to tag the base which triggers something else on the field (perhaps involving the chain?), which their alliance partner must handle? Or we could see robots that could do both? The return of the mini-bot (think 2002) perhaps?
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
  #74   Spotlight this post!
Unread 06-01-2005, 18:46
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
I really hope the project light isn't for an infrared beacon. I remember reading somewhere that radioshack project boxes are actually transparent to infrared light despite being opaque to visible light.
Yeah but the paint isn't going to help. I can get my infared remote control to reflect of of flat paint walls.
  #75   Spotlight this post!
Unread 06-01-2005, 18:54
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
If there were multiple boxes in the BOM, and that was true, that would add a lot of weight to the robots-distinguish-between-objects-indistinguishable-by-eye theory.
Team 1257
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
Fantasy FIRST suggestions for next year Joe Ross Fantasy FIRST 39 14-04-2004 01:13
New Competition in MI, Mailing List Allison K Off-Season Events 0 29-03-2004 19:53
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
