Go to Post ...remember, this is coming from someone that spent the better part of an afternoon playing with an omniwheel--not assembling, not disassembling, just playing. - Billfred [more]
Unread 04-01-2005, 16:35
President, VEX Robotics, Inc.
Hypoid
Here is a picture of a hypoid gear. It is used on an automotive painting robot that my company manufactures.
Unread 04-01-2005, 16:36
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Worm Gear Gearbox
Originally Posted by Adam Y.
Actually efficiency might not be an issue if you properly design the gearbox. A little bit of engineering and you should be able to get the efficiency fairly high. Of course a little research shows that the efficiency can reach 60%.
I'm going to have to strongly disagree about efficiency not being an issue.
Even with your research, which I won't refute, 40% losses in a single stage of a gear set is still quite large compared to the 10%-15% losses over an entire drive train with spur gears and chain.
It should be noted that Adam's article did cite a 97% efficiency for a multiple stage gear train using worm gears, which I found to be quite impressive. (Costs? Yikes! )
Worm gears have their place, but I would strongly discourage their use on a drive train if you're just looking to reduce your gear ratio. I'd definitely like to see justification addresing the losses, which we can all admit are several times larger than spur gears.
(See Paul's link for an appropriate application.)
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 04-01-2005, 16:38
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
The worms we used last year were 35:1 on the back of another transmission. I don't recall the ratio for the Bosch tranny we used however. We wanted an extremely high torque setup for our application though.
Pete
Unread 04-01-2005, 18:02
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
Here is a design for positioning worm transmission from team 107 , the nice thing about our design is that there is 50 to 1 reduction on the worm which should make it not back drive. yet you can quickly change speeds and motor combination. It also can have either a pot or encoder mounted simply.
Thanks Jim schaddelee team 107
Unread 04-01-2005, 18:35
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We used two FP's last year to build a winch for climbing the bar. Be very careful about efficiency loss - we had ~ 30% loss. But it did lock up nicely and keep us hanging
Here's an mpeg of it running
ID:	2723  Click image for larger version
Unread 04-01-2005, 19:38
Doug
That looks great ,what was your reduction and did you lubricate the worm with anything?
Jim Schaddelee team 107
Unread 05-01-2005, 11:46
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
To be honest I have seen a design that could work but it is really weird. It's the triple crown of complexity because it combines a worm gear, a cone drive, and a differential to increase the horsepower of a motor. The only disadvantage is speed is lost.
Unread 05-01-2005, 12:00
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Originally Posted by Dr.Bot
I did this as an experiment using the plastic gearboxes, shafts and axels suplied by first and purchased gears - there is a post somewhere of someone else who did this. The Chippawa moters fed into this I think it was a 30 fold reduction - so the speed was about 4fps. So comparable to a Fischer Price, but much more powerful, Unfortunately my entire robot platform was thrown out in a fit of spring cleaning - the gears cost about 300 bucks for two sets.
I had some pictures, put heck if I can find them.
SO worm gears will work, and you can make the transmissions with just a good drill press if you are carefull and precise.
I got the gears from "Boston Gear"
worm GH1076RH gear G1071RH
Boston gear also produces stock worm drive gear boxes, they're really efficient for worm drives and are quite heavy duty. we used one in our drive train last year and it worked beautiful. Picture Here. I beleive these were a 20 to 1 reduction and these had no backdrive.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 05-01-2005, 12:10
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
-Pat
I did not think that you could buy gearboxes. I was under the impresion that you could only manufacturing them. Plus what is the fun in using premanufactured gearboxes, you dont even get the headaches or any of the flesh wounds that come with designing and building a custom gearbox. That is what makes it fun or at least when it is all over.
"I'm sorry, after all he is just a wookie!"
Unread 05-01-2005, 12:18
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Yes, you can buy gearboxes. Here is a well known example.
This is really up to the needs and opinions of each individual team.
If they feel that a purchased gearbox will meet their needs better than one that they designed and built themselves, then they should by all means go for it.
If they feel that they want the experience of designing and building their own, and have a unique design that they feel would meet their needs, then they should go ahead and do it.
The decision to buy or build is a matter of what each team feels is best for them.
For more thoughts on the matter... this thread.
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 05-01-2005, 12:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
For the most part, you can use whatever you can buy off the shelf, mechanically. So gearboxes are perfectly legal as long as they aren't custom made. Viz. AndyMark
Most people talk about building gearboxes for custom functions that an off the shelf one wouldn't fit for, or more commonly for a shifting transmisson that is difficult and expensive to obtain off the shelf. Or was, at any rate. See: Nothing But Dewalts
Unread 05-01-2005, 14:39
In the case of off the shelf worm gear transmission, aka speed reducers, a COTS part is much heavier than a custom one. My experience with these is that they designed for heavy machinery and not the applications that we have.
One of the best off the shelf transmission choices 177 has made in the last few years was to get the trailer jack the chip was designed for and use that to power our shoulder in 2003. There are lots of good Commercial Off The Shelf parts if you know where to look.
Unread 05-01-2005, 14:50
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
341 used a worm gear gearbox last year- we had a CIM geared down to match the drill motor on both sides, she wasn't as fast as we would have liked her to be (efficiency loss), but the entire year we never got pushed once- many times we met teams with much more powerful transmissions and they couldn't budge us, our frame got really beat up from that
but seeing as our main strategy was to hang quickly from the ground, winch up to the platform, and move back and forth on the platform, it was nice to know nobody could push us.
I personally am a fan of the multi-speed gearboxes over this worm gear gearbox, but if there was ever a game where you want to be a unmovable rock, like if you have to guard something, this gearbox is your man.
Unread 06-01-2005, 21:54
dddriveman's Avatar
AKA: Driveman
Maybe this years game will give us a reason to produce a gearbox with wormgears. I would get no greater satisfaction out of life than watching another bot try to push us around.
Unread 06-01-2005, 22:06
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Does anybody have any links to information for calculating worm gear strength?
Team 1257
gears Michael Leicht Inventor 12 16-09-2004 10:52
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Van Door Worm Gear Jim Giacchi Motors 4 16-12-2003 09:35
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
