Re: New Serial Port Driver
Thanks for your reply... I dusted off my Visual Studio and compiled the Visual Basic program VBTerm.vbp (from the MSDN library). Ran VBTerm and can get into the SMiRFv2 config... So far, so good... I haven't got the pair to recognize each other yet ("Remote Configuration Change Failed!"), I'm making progress... [EDIT] Update: Everything is working fine now that Hyperterminal is not in the loop. Thanks again.[/EDIT] Thanks for your help. Last edited by Mike Betts : 07-01-2005 at 21:19. Reason: Status Update |
Sorry for a Stupid question;
I have added the printf.c/.h and the serial.c/.h (or whatever its called) to last years code. I added the following line to my user_routines (we call ours user_routine_1): printf("hello world"); and got a syntax error. then I added: stdout = TWO; printf("hello world"); and still got a syntax error, but on the printf line, not the stdout line. Help |
#include, not include, DUH
Ok, a question for Mr. Watson,
in your printf.c file there is the function parsing. What screen were you using when you parsed these. I ask because while looking at the website you linked to, I was intrigued by the large letter screen, but I assume I would have to re parse? |
| TTL Serial Port and PS2 Mouse Interface | cbolin | Electrical | 8 | 29-12-2004 15:00 |
| ifi loader with no serial port | Jared Stofflett | Programming | 4 | 23-02-2004 22:50 |
| USB to 9-pin serial port (HELP!!) | n00b | Technical Discussion | 10 | 01-02-2004 21:25 |
| Win32 serial port - recieve buffer | seanwitte | Programming | 4 | 05-11-2003 21:41 |
| Ever seen this serial port problem before??? | Aidan F. Browne | Programming | 5 | 05-02-2003 12:03 |
