Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Unread 08-01-2005, 13:50
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Manipulating tetras from the ground.
I am unable to find any rules that govern the manipulation of tetras on the ground.
Certainly, the vision tetras must be manipulated, as they begin on the ground. Furthermore, since it is possible to descore tetras within the goals, it follows that it should be possible.
But are there any other restrictions? Can they be used as blocking mechanisms? Et cetera.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 08-01-2005, 17:03
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Manipulating tetras from the ground.
I believe so. We had at least three people on laptops with the rules, ensuring any strategy ideas we had were legal, and that was one of the things we thought of...
Unread 08-01-2005, 18:30
Petey's Avatar
Strategy & Gaming
AKA: Chris Peterson
I'm interested that they weren't more explicit. If memory serves, they were far more restrictive with the Stack Attack challenge, which was quite similar.
Ah well. More stuff to do, then.
--Petey
Bio:
Unread 08-01-2005, 23:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I havnt found anything aside of damage to the field that would limit you in the manual.
Unread 08-01-2005, 23:19
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You can pull any tetras that are lying on the floor, inside of a goal out. That's the only descoring of tetras you can do.
2001-2004: Team 100
2006-Present: Team 254
RE:Removing Tetras matt111 Rules/Strategy 40 12-01-2005 12:48
Using ground stem for power distribution steven114 Electrical 9 23-02-2004 11:40
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Ground Stud Teedoff101 Electrical 11 16-02-2004 07:20
Can we ground our wires to the frame? mnkysp6353 Electrical 1 15-02-2002 20:47
