Go to Post In Soviet Russia, FTC support you! - AdamHeard [more]
Unread 08-01-2005, 15:08
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
Smile Basic Game Breakdown
All information obtained through the game manual and the introduction video and put together in the noggin of Adam Levin
Game Elements and field design and robot design-
-Match is now 2 minutes 15 seconds long
-Tetrahedron shaped goals are placed around the field in 3 rows of 3 like a tic-tac-toe board
-Teams are now 3 VS 3
-field is 27ft by 54 ft
-scoring objects are smaller tetrahedrons called tetras (regular tetras are about 8 1/2 pounds and vision tetras are 12 1/2 pounds)
-there are 8 lower tetras that stand at about 5 1/4 ft tall
-one center tetra goal is elevated on a 43 inch tall base and will be about 7 feet from top of the tetrahedron to the bottom of the base
-there are also 2 attendent tetra loading stations placed around the field
-there are 2 manual (human player controled) loading stations on the other side of the field
-there are 2 special Vision Tertas placed randomly on the field just before autonomous starts
-robots must not exceed 28x38x60 in tall
Autonomous Mode-
-During Autonomous your robot can pick up a special vision tetra and place it on a goal for bonus points
-another option is the there are 2 hanging tetras on either corner goal that the robot can know down for extra points
-bonus points are added to your corner goals between end of autonomous time and human controled time
-for extra points during autonomous vision tetras mustbe placed on any of the 3 center goal or the 2 corner ones on your side of the field
Human Player Element-
-Human players (1 from each alliance) are standing on pressure pad "mats" on the side of the field
-If human steps off this pad any time during the match, your robot is disabled until the human goes back on the mat.
-with the 2 manual (human player controled) loading stations, when a robot goes onto the loading symbol the human can step off the mat and place a tetra manually on the robot and then return to the mat to reativate the robot once again
-when loading a tetra, the human may have no contact with the robot
Game Play-
-Robots must place the tetras on top of the goals
-The loading stations will be opperated by a field attendant and when a robot takes a tetra from this station it will be replaced with another by the field attendant but they may be oriented differently each time
your robot cannot interfere with opposing robot while ANY part of it is touching the loading zone
you may only be given 1 terra at a time by the human player (though it looks like you can just go back on and off the loading zone repeatedly and keep collecting tetras)
robots cannot "grab, grasp, grapple, or attach to the GOALS or any other field structure"
after autonomous robots can place tetras on any goal on the field
to make a row your colored tetra must be the top tetra on the stack or every goal in that specific goal
opponents may counter a row by placing one of their colored tetras on top of yours
Scoring-
3
points for each tetra stacked on top of a goal (in order to be concidered stacked one must ask that if the supporting objec is removed will the tetra still remain on the goal)
point for each tetre placed on floor in base of the goal (tetras must not be touching any area outside the containment area under the goal)
10
points for each row of tetras you make when you colored one is the top one on the stack
10
points if all 3 robots in your alliance are behind the starting line at the end of the match
This is just the bear bones but this can be a huge help for the time being.
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
Unread 08-01-2005, 15:29
Avarik Avarik is offline
Avarik is an unknown quantity at this point
Re: Basic Game Breakdown
Can you make a stack of tetras, or carry around more then one at a time? What about grabbing one from the attendent loading zones (not the human player ones) and waiting for them to reload to grab another?
Unread 08-01-2005, 15:40
Levin571's Avatar
DC Regional VC
"A field attendant will be positioned behind the Tetra Loading Station, and will place a Tetra on the loading station each time one is removed by a Robot. Minor variations in the precise position and orientation of the Tetra on the Tetra Loading Station are to be expected, and are considered part of the challenge of the competition."
So from what i can interpret you can just keep going back on and off the loading area and keep collecting those terra's and i would expect you to be able to carry more than one at once since i'm looking through the rule and see nothing contrary to that
2006 Scout
Co-Founder of FF
Unread 08-01-2005, 15:46
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
As far as waiting, G17 states that the robot must leave the loading zone and return beforebeing allowed to grab another tetra
Unread 08-01-2005, 16:13
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
is there a limit to the number of tetras allowed on the field?
I'm proud to be a...
Unread 08-01-2005, 16:25
Levin571's Avatar
DC Regional VC
considering the idea that every tetra could theoretically be used to score it seems that there is no limit to the amount that can be in play at once. it mostly depends on how quick you are and if you want a whole lot of tetras on the field
2006 Scout
Co-Founder of FF
Unread 08-01-2005, 16:43
kevin.fort kevin.fort is offline
President-Team 1001
FRC #1001 (Hacksaw Robotics)
kevin.fort is on a distinguished road
Send a message via AIM to kevin.fort
well there is a total of 40 tetras at each game but i am fairly sure that you can have all of them on the field at once. at least i have read the rules and it doesnt say anything about haveing a limit
Unread 08-01-2005, 17:01
Christine G.'s Avatar
Christine G. Christine G. is offline
#0061 (Intimidators)
Christine G. is on a distinguished road
What is the starting position of the 40 tetras? How many do the human players start with and how many are there for the Auto Loading station?
2004 Mayhem on the Merrimack Champions
2004 Beantown Blitz Champions
2004 Florida Regional Champions
2004 Winner of UCF Regional Judges Award
Unread 08-01-2005, 17:06
Levin571's Avatar
DC Regional VC
from what i've read so far 4 start on field, and the rest are split between human and auto loading station
remember that if you get a bonus during autonomous, some more are added automatically to your corner goals
2006 Scout
Co-Founder of FF
Unread 08-01-2005, 17:10
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Actually, four vision tetras (the ones with neon green for sensors) are on the field (two red, two blue), and four tetras are hanging from the exterior goals (two red, two blue).
Unread 08-01-2005, 17:12
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Do you actually have to CAP the vision tetras, or can you put them in the goal to get the bonus tetras?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 08-01-2005, 17:14
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
don't forget about the tetra that one robot can start with
my interpretation is that you need to cap the goal with the vision tetra
http://www.wcsrobotics.com
team 663
team 1493
Unread 08-01-2005, 17:16
Levin571's Avatar
DC Regional VC
<G10> If during the AUTONOMOUS PERIOD a VISION TETRA is STACKED on a GOAL located on the edge of the field, a bonus TETRA will be STACKED on the nearest corner GOAL in the alliance END ZONE. If during the AUTONOMOUS PERIOD a VISION TETRA is STACKED on the CENTER GOAL, a bonus TETRA will be placed on both corner GOALS in the alliance END ZONE. All bonus TETRAS will be STACKED on the GOALS by field attendants at the earliest safe opportunity after the end of the AUTONOMOUS PERIOD. Once the AUTONOMOUS PERIOD ends, all VISION TETRAS are treated and SCORED as regular TETRAS for the remainder of the match.
2006 Scout
Co-Founder of FF
Unread 08-01-2005, 17:53
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
Does Rule G15 mean that if my robot bumps a robot in a loading zone during auto mode, I will be punished?
Ken
Ken Loyd
Teacher/Advisor
Team #39
Highland High School
Unread 08-01-2005, 18:05
I'm baaaaaaack.
No, the LOADING ZONEs are the areas for the robot to pick up tetras, either handed from the players at the "manual" loading zone, at which point it's disabled due to pressure pads, or for the robot to pick up tetras itself at the "automatic" loading zone. The autonomous period is for the robot to pick up vision tetras by itself, or position itself near or on one of the pressure pads for you to hand one to it after the autonomous period once it switches into the driver period, if you can't get the camera to work properly for you.
Because of this, it is very doubtful that you'll actually bump a robot during the autonomous period unless the robot color is the same blue, red, or green that the tetras are, in which case, it'll probably be up to the judges as to whose fault it is.
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
TV Commercial Game - Rules and Regulations Elgin Clock Games/Trivia 6 01-12-2004 19:07
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
