how well do the sensors pick up color?
Looking at the kick-off video and seeing the vision tetra's ,ones that are placed on the Field that weigh 12.5 lbs, the color on them is red or blue and green panels. my question is What if your Robot is one of those colors, like my team MOE 365 is, will that affect the the sensors on the robots and lead them away from the tetras and to wards our bot or are the sensors "smart enough" to to not do that?
Re: how well do the sensors pick up color?
As stated in this thread: http://www.chiefdelphi.com/forums/sh...threadid=32226 , and in the manual:
<R26> No devices or decorations are permitted on the robot that are intended to jam or interfere with the operation of the vision system (i.e. changing robot color to confuse opponent’s vision system). I think that MOE green is different enough from tetra green that the vision system should know the difference, but I dont know how precise the sensors are. Eric Last edited by ebmonon36 : 08-01-2005 at 16:14. |
Eric |
I was thinking about this earlier. What are the odds that the robot will pick up on colors outside of the field? Suppose the root locks onto a person wearing green colors.
#7
Well, then they would be disqualified for leaving the field area...
#9
If objectsize >3 Then gotoandpickup Else turncamera45degreeright Last edited by Adam Richards : 08-01-2005 at 17:04. Reason: Modifying quote for better understanding |
#11
Once again I am not trying to sound argumentative or anything I am just trying to get a good interpretation of the new rules and if our color might cause a problem on the field then it may have to change. |
#12
I suppose the trade off for not having those colors available for teams is that the field won't be colored mustard yellow, or any other hideous shades. Besides the RGB spectrum is big, can't we all just share nicely
.Once we get a robot running though, i guess my team will have to see how the colors interfere. My teams shirts a shade of red not that far from what is used. If enough of us clump together in the stands, some robots might do funny things. ![]() |
#14
From what I've read about the CMU in the past, I think it just looks at the entire picture, finds a color, and feeds back the coordinates. Simple solution might be to use an IR ranger (or Ultrasound) if you can get it to work, so that you can set maximum ranges.
#15
What I'm wondering about the cameras is how big of a deal would ambient light have on what it picks up as a set color? Say at home in what ever setting you are working in, say the correct green is defined at 3.5<x<3.7, or around that range, but in a match for what ever reason due to lighting used there the threshold gets knocked up to say 3.9<x<4.2? it will become hit or miss at times.
I know its kinda specific the ranges, but chances are if not the robot may track anything that could be considered at all greenish in its visual range |
| Color codes for new versions of anything? | Elgin Clock | General Forum | 7 | 16-12-2004 20:16 |
| Is this a valid technique? (Color application to metal) | Elgin Clock | Technical Discussion | 8 | 09-06-2004 21:33 |
| Getting Fancy with Sensors | FadyS. | Programming | 30 | 10-03-2004 15:02 |
| Why not analog sensors?? | gnormhurst | Programming | 16 | 07-03-2004 16:14 |
| what type of sensors are good and convenient | magical hands | Programming | 7 | 04-01-2004 23:04 |
