Go to Post Robotics is about people. It always was, it always will be. What more guidelines do we need? - Ken Leung [more]
Unread 08-01-2005, 16:14
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Knockin of tetras
EDIT: Well, my first search didn't bring up any results, but now I look at the 'similar threads' down in the bottom and have my answer. Sorry!
I think I know the answer to this, but I just want to clarify...
Is there anywhere in the rules that says that you can't knock the tetras off the goals?
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 08-01-2005, 16:18
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: Knockin of tetras
yes you can not "uncap" the tetras if they are seated the right way on the goals but if they are not on the right way then u can take them off or adjust them, there is a 10 pt penalty for uncapping and the other teams gets to OWN the goal for the rest of the match.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 08-01-2005, 16:29
Aburame Shino's Avatar
Aburame Shino Aburame Shino is offline
Professional Gamer
FRC #0093 (N.E.W. Apple Corps.)
Aburame Shino will become famous soon enoughAburame Shino will become famous soon enough
<G18> ROBOTS can remove or displace TETRAS CONTAINED in a goal, but cannot remove TETRAS
STACKED on a goal. If an alliance ROBOT removes any STACKED TETRA of the opposing alliance, the
TETRA will be SCORED (3 points) and the opposing alliance automatically OWNS the GOAL for the
remainder of the match regardless of what color TETRAS are on the goal. There is no penalty for removing a
TETRA that is precariously positioned on a GOAL or TETRA, but not fully STACKED.
Unread 08-01-2005, 16:35
kevin.fort kevin.fort is offline
President-Team 1001
FRC #1001 (Hacksaw Robotics)
kevin.fort is on a distinguished road
Send a message via AIM to kevin.fort
you are not allowed to knock off tetras
if you do you give the opponent a lot of points as well as permanent control of the goal no matter who has the tetra on top
Unread 08-01-2005, 16:51
Avarik Avarik is offline
Avarik is an unknown quantity at this point
Even if it is your own tetra?
Unread 08-01-2005, 16:59
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
unless FIRST clarifies this later, even if its your own tetra
Unread 08-01-2005, 17:13
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Since this rule is unclear, I've asked the question in the FIRST FRC Q+A System (#966). Hopefully there'll be an answer soon.
Unread 08-01-2005, 17:23
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
http://www.wcsrobotics.com
team 663
team 1493
Unread 08-01-2005, 17:42
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
FRC #0364 (Team Fusion)
jdhawg will become famous soon enough
After pondering this for a few moments, I just have to ask..... Why would you want to remove your own tetra?
Unread 08-01-2005, 17:50
President-Team 1001
well the only reason i can think of to remove your own tetra is if you already have that scoring tetra owned even if you take your tetra off, and you are out of tetras(which is almost impossible) and you want to break up an opposing three in a row then you would wan to use that tetra so you can stop you opponent from getting those ten points which are so crucial in the outcome of the match
Unread 08-01-2005, 21:18
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
See this thread.. all about removing tetras..
http://www.chiefdelphi.com/forums/sh...ad.php?t=32220
You can't remove any tetra from the top of a goal, if it's stacked properly. If it's "precariously" sitting on top of a goal, you can take it.... Hopefully it will be completely obvious when a tetra is not fully seated, though it would be difficult to get it balanced to remain precariously seated..
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 08-01-2005, 22:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Bah there goes my plan to balance a tetra upside down on the goal to make it virtually impossible for them to take the ownership away.
RE:Removing Tetras matt111 Rules/Strategy 40 12-01-2005 12:48
Basic Game Breakdown Levin571 General Forum 34 08-01-2005 23:35
Manipulating tetras from the ground. Petey Rules/Strategy 4 08-01-2005 23:19
