Go to Post A lot of students decribe FIRST as the best thing that happened to their life. Once a student gets hooked, they don't want to leave FIRST for any cause. I am one of them. - Arefin Bari [more]
Unread 01-12-2004, 15:56
phoenixomega001's Avatar
phoenixomega001 phoenixomega001 is offline
AKA: Bilbee
#1518
phoenixomega001 is an unknown quantity at this point
Send a message via Yahoo to phoenixomega001
Question user code to default code
I am trying to run a user prgm from the default code supplied from Innovation First but it will run what I program but it stops when the loop is done or not at all and doesn't acnowlage the single joystick input.
Unread 01-12-2004, 16:06
Re: user code to default code
post your main.c file.. there may be a problem with the loop.
Unread 08-01-2005, 18:08
kevin.fort kevin.fort is offline
President-Team 1001
FRC #1001 (Hacksaw Robotics)
kevin.fort is on a distinguished road
Send a message via AIM to kevin.fort
where did you get the 2005 default code?
Unread 08-01-2005, 18:15
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
this is a little off topic, but are these normal "errors" in mplab compiler?
Clean: Deleting intermediary and output files.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\encoder.o" doesn't exist.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\ifi_startup.o" doesn't exist.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\ifi_utilities.o" doesn't exist.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\main.o" doesn't exist.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\printf_lib.o" doesn't exist.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\user_routines.o" doesn't exist.
Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\user_routines_fast.o " doesn't exist.
Clean: Deleted file "encoder.cof".
Clean Warning: File "encoder.cod" doesn't exist.
Clean Warning: File "encoder.hex" doesn't exist.
Clean Warning: File "encoder.lst" doesn't exist.
Clean: Deleted file "C:\mcc18\05\frc_encoder\frc_encoder\encoder.m cs".
Clean: Done.
mplab says there weren't any errors, but I was wandering if the statements above mean anything isn't configured correctly. thanks,
Stephen
Unread 08-01-2005, 18:18
you get it here http://www.ifirobotics.com/rc.shtml
Unread 09-01-2005, 00:09
Clean: Done.
Stephen
That's all normal.
Clean is deleting intermediate files generated when the code is compiled, linked, etc. In your case the files Clean was making sure were deleted had already been deleted. It gave you the warnings just in case you wanted to know.
What Features Should the Default Code REALLY include? Joe Johnson Programming 30 29-04-2004 22:39
Strange IR sensor movement with default tracker code wun Programming 5 19-03-2004 10:51
Bringing in Navigate.zip into the Default code alexrobotics Programming 1 24-02-2004 21:42
Is default code already loaded? quickie25 Electrical 8 19-02-2004 22:51
