Re: user code to default code
this is a little off topic, but are these normal "errors" in mplab compiler?
Clean: Deleting intermediary and output files. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\encoder.o" doesn't exist. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\ifi_startup.o" doesn't exist. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\ifi_utilities.o" doesn't exist. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\main.o" doesn't exist. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\printf_lib.o" doesn't exist. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\user_routines.o" doesn't exist. Clean Warning: File "C:\mcc18\2005 code (and encoder 2004)\frc_encoder\frc_encoder\user_routines_fast.o " doesn't exist. Clean: Deleted file "encoder.cof". Clean Warning: File "encoder.cod" doesn't exist. Clean Warning: File "encoder.hex" doesn't exist. Clean Warning: File "encoder.lst" doesn't exist. Clean: Deleted file "C:\mcc18\05\frc_encoder\frc_encoder\encoder.m cs". Clean: Done. mplab says there weren't any errors, but I was wandering if the statements above mean anything isn't configured correctly. thanks, Stephen |
| What Features Should the Default Code REALLY include? | Joe Johnson | Programming | 30 | 29-04-2004 22:39 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Strange IR sensor movement with default tracker code | wun | Programming | 5 | 19-03-2004 10:51 |
| Bringing in Navigate.zip into the Default code | alexrobotics | Programming | 1 | 24-02-2004 21:42 |
| Is default code already loaded? | quickie25 | Electrical | 8 | 19-02-2004 22:51 |
