Go to Post If you want to grow the program such that every student on the planet has the chance to participate, you have to start THINKING with a world-centric mindset. - Racer26 [more]
Unread 08-01-2005, 15:57
schenkin schenkin is offline
schenkin is on a distinguished road
Autonomous Commands Promised in Kickoff
In the kickoff we where promised either seperate commands or scripts for autonomous mode. In particular, code to interface with the camera. Does anyone know where I can get that or if it is even out?
Programmer
Team 486
Unread 08-01-2005, 16:03
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Autonomous Commands Promised in Kickoff
Programmer
Team 486
http://www.ifirobotics.com/camera.shtml has the "getting started" zip file which includes the camera manual and FRC code.
Unread 08-01-2005, 18:27
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
where do you get info on the scripting commands? is there going to be a program to do this with. It seems that it will be a program that you write the scripts and then the program writes the c code for you. but I don't know where it is.
Unread 09-01-2005, 15:47
I was using the simulator option in mplab, and it gave me this error like 100 times in a row, and then stopped simulating. "UART-W0001: Overrun, write occured over a full TXREG SFR. Data lost". though, there was one error before all those errors that said "UART-W0006: Receive file has no data or failed to attach when UART receive mode Enabled." the line of code it pointed to was printf_lib.h. anybody know what's wrong with this? it pointed me to a place in a file that had this line of code
" Wait4TXEmpty();". any help would be appreciated.
Unread 09-01-2005, 16:23
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
It is trying to communicate through the serial port (even in sim mode) to which nothing is connected. It's expecting to see some data and there is none to see so you are getting the error. You shouldn't see this when you connect up the RC and Camera.
Sean
Unread 09-01-2005, 16:31
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Ok, I am trying to compile the default FRC code in MPLAB 7 with the C18 v 2.4 compiler.
I added Kevin Watsons Serial Ports, Printf, Interrupts, and Encoder files. After every file I added, I called them in all the right places, and built all, with no errors.
Then I added the CORDIC math libraries and built, no problem.
Then I added the camera serial driver files and got a build error:
Error - could not find definition of symbol 'Serial_Char_Callback' in file 'C:\Documents and Settin. . .base\user_SerialDrv.o'.
Errors : 1
The funny thing is, I removed the files I had just added, and the error persisted, in a build which had worked 5 minutes before.
Thoughts?
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 09-01-2005, 16:55
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
Where do we get MPLAB 7?
Unread 09-01-2005, 16:59
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
I think you can get it from here:
http://www.microchip.com/stellent/id...ame =en019469
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 09-01-2005, 17:01
http://www.chiefdelphi.com/forums/sh...689#post315689
Unread 15-01-2005, 22:30
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Are encoders required for the given automous commands to work?
Unread 16-01-2005, 05:16
jparkteach's Avatar
jparkteach jparkteach is offline
FRC #2070 (Ridgefield Robotics)
jparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to behold
Send a message via AIM to jparkteach
In essence, YES! I'm not sure, however, if the Hall Effect Sensors could be used instead...
Unread 16-01-2005, 08:58
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I posted about this here
and Kevin Watson's response is here
Yes, you require them if you don't want to modify the code. No, you can use the Hall effect gear tooth sensors if you modify the code slightly to garner direction information from which way you're running the motors.
-SlimBoJones...
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
**FIRST EMAIL**/Important Manchester Kickoff Information Rich Wong FIRST E-Mail Blast Archive 4 21-12-2004 17:02
Qotw [11-17-02]: Manchester or remote kickoff... Ken Leung Rumor Mill 19 09-01-2004 16:18
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
