#31
Re: Concerns regarding the green paneling/green shirts
Dave |
#32
also i think the goal of the software is to focus on one thing and then follow that so maybe if you dont ask it to reaquire green or whatever in the middle of the run it would do just fine |
#33
We were discussing this earlier, and I would have thought the people at FIRST would have thought this through. It seemed that in the webcast, Dave Lavery's shirt had to be pretty close to the robot. This season should be pretty intersting. |
#34
--Petey |
#35
I happen to know if a team in Vt that in fact has had a very nice looking Green robot. I'm sure this will be a question asked to First....it will be interesting to see what the answer is. (will teams be forced to give-up their identity color!) -Quentin |
#36
I am less concerned about a false trigger on the vision system from green anythings, (including humans) than I am about variations in lighting from venue to venue. When a material looks green to you it may not appear green to a camera depending on the color of the light. It may not even appear to a camera if the light is reflecting in the right way. I think that if you read the paper on visualization you might get a better handle on how this recognition works. I would think a robot would only get in trouble if it had a green stripe of approx the same height and width as the tetra and the same altitude and texture. What I am saying is test like crazy to be sure.
#37
the CMU cam can't hardware adjust it's sensitivity. Physically, the CMU cam is made of two pieces, the camera and the gpu. You can adjust the camera's focus; I'm not sure what the supplied gpu can do, hardware wise. I use the CMU cam (older one) on my own robots, it's fairly sensitive to color differences until it starts loosing focus.
#38
Here is the (two part) question that I posted in the forum: Quote:
If 811 built their normal red robot, and a team tried to sense the red tetras, the robot would be attracted to you, wouldn't it? Similarly, if a robot was built to sense the loading dock (yellow), and they went against Buzz, the Buzz robot could be mauled, couldn't it? Interested to hear the answer. That's just one of the 7 or so questions I posted. --Petey |
#39
It will be difficult to test like that when you're concerned about other robots, though. Think about it--that robot followed Dave around, and it also followed the green tetra, if I'm not mistaken. Those were wildly different greens. --Petey |
#40
Well, certain members of our team, who will remain unnamed
*cough* me *cough* have already begun a list of the top things the judges *DON'T* want to hear this year. The top of the list - "Well, it's your own fault for wearing that color. Don't blame us!" We're just worried 'cause our shirts look like almost the same colors as the blue tetras. That might be a problem in practicing. I guess the same is true for green teams and red teams in practice matches. All I know is that I've already been instructed never to wear my tie-dye around the robot... it's already tried to get me enough times. ![]() |
#42
Interesting then.
I just want to see the answer. --Petey |
#43
Really? My impression was you were just going to home into the green color that's only on the vision tetras. No need to look for other colors, the green is all you're interested in. What was your thinking? |
#44
i really don't think that the colors will have that much of an effect, i have been thinking about this alot and i have also been looking up info on the sensors and a team should be able to set the sensors to only pick up the exact color and the sensor will mostly work in the area it is pointing in, remember in the kickoff the sensor was mounted high to follow Dave, since the tetras are kinda low to the ground there shouldn't be much of a problem. at least i hope not..
#45
-Daniel |
| What is on your 2004 Team shirts? | Elgin Clock | Team Organization | 14 | 06-10-2004 18:58 |
| How Many FIRST shirts do you own? | Joe Ross | General Forum | 81 | 31-08-2004 10:36 |
| [ECDU]: CHAT-7/19 | Corey Balint | FIRST-related Organizations | 5 | 19-07-2004 23:44 |
| Reputation points | SilverStar | CD Forum Support | 73 | 26-05-2004 02:14 |
| shirts and things | illumanat'i | General Forum | 15 | 15-01-2003 16:31 |
