Go to Post Representing data in a good way is an art in its own right. - Andrew Schreiber [more]
Unread 08-01-2005, 18:47
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
Re: Tetra Rods Steel, not PVC?
The most important part wether it is steel or PVC is weight, and the manual states that the "non-vision" scoring tetras weigh in at around 8.5lbs, where the "vision" tetras are around 12.5 lbs. (Sec 3.3). In the webcast, the BIG tetras that the scoring ones were to be placed on were made out of steel.. hope that helps
Jay
which is better aluminum or steel???? SCYTE16 Kit & Additional Hardware 50 24-11-2005 13:35
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
Goal...PVC is loose... archiver 2001 7 23-06-2002 22:38
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
