RS-232 TTL Board?
We're inventorying and even our electonics expert has no idea what this part is. I can only find it in the checklist. Any ideas?
Re: RS-232 TTL Board?
It is used to connect the camera board to the RC. Read the camera documentation for more information.
<edit> Oh, you meant what it looks like, and where to find it? It's in the bag with the IFI camera board (not the camera itself). It's the piece of PCB about the size of a nickel. </edit> Last edited by jgannon : 08-01-2005 at 19:33. Reason: More info |
I think this board plugs into the cmucam2 video board which only has TTL comm. The little converts TTL to RS232.
Learn more about the CmuCam2 @ http://www.seattlerobotics.com/image...am2_manual.pdf It's a really cool device and very easy to use. Good Luck ![]() |
Thanks! We saw this. One other related question, then - what is the tiny board that goes with it?
Right
![]() EDIT: Just saw this in Doug C's post... Sorry! |
#8
Simple Explanation here...
The purpose of that board is to convert voltage levels. Standard logic levels for ICs and small devices is 0-5v, like the RC or OI. However, when transmitting data over a wire, it is nice to have more noise margin, and one way to achieve this is to jack the voltage differential. RS232 voltage levels do just that. Your standard legacy pc has a serial port that uses RS232 voltage levels, whereas the RC has a TTL level serial port. I built one of those modules last spring to interface the edubot to a matrix orbital lcd screen. The link below has more detailed information. http://www.beyondlogic.org/serial/serial.htm#1 I assume, w/o having access to a kit right now... that the rs232->ttl converter is just a max233cpp chip or equivalent with appropriate connectors. The digikey part number for that chip is: MAX233CPP-ND The datasheet is: http://rocky.digikey.com/WebLib/Maxi...u%20MAX249.pdf |
#9
Thanks for this information. I'll be looking at it in much more detail later.
| Perf Board = BS2-IC Carrier Board? | indieFan | Electrical | 2 | 16-09-2004 08:28 |
| Shelf and board dimensions still don't add up | kmcclary | Off-Season Events | 12 | 20-10-2001 09:12 |
