Go to Post Not winning is different than being a loser. - seanwitte [more]
Unread 08-01-2005, 19:37
Sidney San Martín's Avatar
Sidney San Martín Sidney San Martín is offline
FRC #0555 (Montclair Robotics)
Sidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura about
Re: RS-232 TTL Board?
Thanks! We saw this. One other related question, then - what is the tiny board that goes with it?
Unread 08-01-2005, 19:41
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
It IS the tiny board (as I said, about the size of a nickel). The larger board is the IFI camera board, the one that you plug the CMU camera into.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2005, 19:43
Right
EDIT: Just saw this in Doug C's post... Sorry!
Unread 08-01-2005, 19:49
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
Simple Explanation here...
The purpose of that board is to convert voltage levels.
Standard logic levels for ICs and small devices is 0-5v, like the RC or OI.
However, when transmitting data over a wire, it is nice to have more noise margin,
and one way to achieve this is to jack the voltage differential. RS232 voltage levels
do just that.
Your standard legacy pc has a serial port that uses RS232 voltage levels, whereas
the RC has a TTL level serial port. I built one of those modules last spring
to interface the edubot to a matrix orbital lcd screen.
The link below has more detailed information.
http://www.beyondlogic.org/serial/serial.htm#1
I assume, w/o having access to a kit right now... that the rs232->ttl converter
is just a max233cpp chip or equivalent with appropriate connectors.
The digikey part number for that chip is: MAX233CPP-ND
The datasheet is: http://rocky.digikey.com/WebLib/Maxi...u%20MAX249.pdf
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
Unread 08-01-2005, 22:46
Thanks for this information. I'll be looking at it in much more detail later.
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Shelf and board dimensions still don't add up kmcclary Off-Season Events 12 20-10-2001 09:12
