Go to Post I'm wondering just what you think the people who DID set this system up actually do for a living instead? Sheep farmers? - DonRotolo [more]
Unread 08-01-2005, 18:15
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
Floating Goals?
im looking over some field blueprints.. and a question came into my mind.
Are any of the field elements secured down?
Knowing the nature of the fields, i dont see how this would be possible. The goals themselves appear to be lightweight aluminum framing. making them quite easy to move on carpet.
and, if they are not... is it legal to move them?
~Phin
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 08-01-2005, 18:25
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Floating Goals?
Moving the field elements result in penalties. I believe they are velcro'ed to the carpet.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 08-01-2005, 18:28
PyroPhin's Avatar
None #0263
Re: Floating Goals?
looking at the blueprints, it says the center goal is secured... clearly shown in the picture as being secured to a metal base
but the other field elements dont seem to be fastened, and just floating.
where did you read about the penalties?
~Phin
Squee!
Unread 08-01-2005, 18:29
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Floating Goals?
The goals are definately velcro'd to the carpet....as well as all the other flat plastic triangles al about the fields. (under the goals, and near the ball entry poiints)
-Quentin
~Phin
Team 4987: Megarams
Unread 08-01-2005, 18:30
PyroPhin's Avatar
None #0263
Re: Floating Goals?
ah, alright. Thanks!
Squee!
Unread 08-01-2005, 19:58
inquiry's Avatar
inquiry inquiry is offline
Inquiry
AKA: Lucas Baker
#1540 (Catlin Gabel School)
inquiry is an unknown quantity at this point
Send a message via AIM to inquiry
Re: Floating Goals?
~Phin
I'd like to clarify a little. Using the keywords "velcro," which is used to secure the center goal, and "move," I searched through "The Arena," "The Game," and "The Robot." However, I found only the following:
"The entire Central Goal is secured to a base that is fixed to the
Playing Field carpet with Velcro to prevent movement."
Personally, I think that FIRST will let you do as you like with all the goals other than the center one. I could not find any rule preventing you from moving the other goals or penalties associated with moving them. If you are still skeptical, then you can always check the rules with FIRST through TIMS.
Assume work is weight. Already the boulder that is homework pressed upon us - then, with wry smiles, we looked to see FIRST's anvil dropping from the sky.
Team 1540 knows what work means.
Unread 08-01-2005, 20:02
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Floating Goals?
This would make for some certainly interesting rows to get 10 pt bonus....I've never seen a row in the shape of a 'S'. If they were intended to move there wouldn't be many rows made now would there? The aren't supposed to move....
Unread 08-01-2005, 20:25
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: Floating Goals?
in the rule book there is only 8 ways to score for rows and that is it if the goals could be moved they would have stated that there were more then 8 ways to make a row, also they would have told us that the goals could be moved because that would add a whole new element to the game.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 08-01-2005, 20:58
Steve Howland Steve Howland is offline
Many years, many teams
FRC #2473 (Goldstrikers)
Steve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond repute
Re: Floating Goals?
You'd have to have a pretty strong robot to move these goals considering you can only push them:
<G20>Robots may push or react against any elements of the field, provided there is no damage or disruption of the field elements. Robots may not grab, grasp, grapple, or attach to the goals or any other field structure. Robots may not extend under, lift up or tip over a goal.
Unread 08-01-2005, 21:02
occra 23.
AKA: ryo
None #1481
Re: Floating Goals?
well ive never seen an S shape with only 3 pieces either. in my mind you can only get a line or a V shape with 3 pieces
and well since these are tetrahedrals they shouldnt be easy to tip either
Unread 08-01-2005, 21:04
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Floating Goals?
That's an interesting point. FIRST specifically mentiond that the center goal is secured with velcro, yes it is not mentioned that the other smaller goals are attached in any manner. I would not be surprised however if that's one of the first issues addressed in an update.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 08-01-2005, 21:22
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
Re: Floating Goals?
at my kickoff one of the gameplay seminar speakers aswered that exact question. He said that all the goals are velcro'd down and cant be moved. also it would be hard to move them because they must be about twice the weight of the small ones which is 9 pounds. i doubt any conventional robot that we could build could do that.
Unread 08-01-2005, 21:41
Kyle's Avatar
AKA: Kyle Rice
FRC #0365 (MOE)
Re: Floating Goals?
some bots from last year had alot of pushing power, think of team 25 they could push almost anyteam out there once they got a lil bit of moementium behind them.
Facebook
Unread 08-01-2005, 21:44
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Floating Goals?
Pushing power and momentum are two different things.
And regardless of how well secured they are to the floor, teams will be capable of moving them. Happened last year with the platforms more than a few times. Don't do it though... you want penalties even less than in previous years... there's going to be A LOT of teams that lose matches because of dumb penalties.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2005, 21:47
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: Floating Goals?
All goals are secured to the floor, trust me, I tried moving them.
Mobile Goals Joshua May General Forum 12 16-03-2004 10:45
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
WOW ! Mike Schroeder General Forum 12 12-03-2002 21:32
Is it weird to see an atwood motor floating in mid air? mnkysp6353 Chit-Chat 6 19-02-2002 21:38
