Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 08-01-2005, 20:38
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Drill Motors Removed? Illegal this year?
I am a first time rule reader this year so please bare with me..
I have seen that FIRST elimated (removed) the drill motors from the kit this year, so if there was a transmission design that used a drill motor, it can not be used this year correct?
quoted from kitofparts.pdf:
"Removed 2 Bosch drill motors & transmissions and replaced them with 2 CIM motors with FIRST transmissions."
It doesn't look like any motors the size of drill motors are included in the kit of parts. (I don't know the names of the motors below and what they look like)
Motor, Globe, w/drive assy
12 Vdc
409A587
Motor, CIM
Keyed output shaft
FR801-001
4
Motor, Nippon-Denso, Window , RH
Motor, Sliding Door
Taigene
Motor, Window, Jideco
RH or LH provided
Motor, Fisher-Price, w/21T #7 Gearbox
12 Vdc,, stall torque 532.19 (mNm)
I assume that you must only use these motors when you build your robot?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 08-01-2005, 20:40
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Drill Motors Removed? Illegal this year?
Yes
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
That is correct. You may only use the motors included with the kits. There was an e-mail sent out to all teams earlier this year (you may not have gotten it, as a rookie, but it was posted here on CD) that warned us well ahead of time that the drill motors would not be included and thus be illegal.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2005, 20:53
Dested's Avatar
Dested Dested is offline
AKA: El Presidente'
None #0498 (Cobra Commanders)
Dested will become famous soon enough
Send a message via AIM to Dested
I thought i read that you can buy more CIP's but im not sure.
2001 Team Spirit Award - Southern California Regional
2004 Sportsmanship Award - Arizona Regional
2004 Finalist - Arizona Regional Thanks (Team 696 & 80)
2004 Master Plan Award - Arizona Regional (Team 60)
2005 #4 Seed - Arizona Regional
2005 Regional Semi Finalist - Arizona Regional Thanks (Team 980 & 96)
2005 GM Industrial Design Award - Arizona Regional
2005 Highest Regional Score - 112 - Arizona Regional
Unread 08-01-2005, 21:03
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Just because the Drill motor was removed doesn't make using a drill motor transmission illegal. The test to determine legal parts is by answering the questions in the decision tree that is in the rules for additiona parts and material.
If a drill motor transmission meets all of the criteria for making it a legal part, then it is a legal part. I believe that the drill transmission is legal, but the drill motor isn't.
Unread 08-01-2005, 21:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You can buy more CIM's as spares, but you can't use more than the four they provided in the KOP
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2005, 21:30
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
That's correct. As I recall, your team used a lot more than two drill transmissions last year. An impressive machine, BTW.
_
Unread 08-01-2005, 22:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Don't forget that FIRST now allows, unlimited Dewalt Gearbox shifters, er ah... ... I mean Hitec 322 Sevros ;-)
Joe J.
Team #88, TJ2
Unread 11-01-2005, 18:53
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Joe J.
BTW...JOE...what regionals are you going to? I REALLY want to thank you. Our robot is NBD this year... You are my hero...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 11-01-2005, 23:02
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Joe J.
Seeing that in the rulebook pleased me greatly... I think you can see why, from Don's post
Jeff Waegelin
Unread 11-01-2005, 23:07
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
It should also be noted that there is only 1 globe motor and 1 Taigene Sliding Door Motor.
From "FRC Public Announcements"
The "Gray Container Item 5 Loose" should have contained 1 motor, not 2. The Kit of Parts list incorrectly specified a quantity of 2.
Globe Motor
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 12-01-2005, 01:08
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
You are only allowed to use the motors in the kit, no substitutions. You can only substitute exact model motors for ones that break.
Yes, you can power any transmission that is safely in the rules with only motors that are provided for you.
Elknise
Issaquah Robotics
Unread 12-01-2005, 09:04
12 Vdc
409A587
Motor, CIM
Keyed output shaft
FR801-001
4
Motor, Sliding Door
Taigene
RH or LH provided
Please read Team update #1 posted yesterday for more info on motors. The numbers were incorrect on your inventory lists. Those motors listed are the only motors that can be used. Please also see the dialog between Dr. Joe and Paul Copioli on the mabuchi motor specs, in the motor forum (or search).
HOT drill motors Rich Wong General Forum 4 29-01-2003 22:38
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Urgent...Modifying this years drill motors Mimi Brown Motors 17 07-01-2003 23:04
Ordering Extra drill Motors mnkysp6353 Motors 1 30-09-2001 03:21
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
