Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 08-01-2005, 16:57
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
How many tetras?
I couldnt find it in the manual, so I'll ask. Is there a set number of tetras that can be used in the game, or we are to asume that the loading stations have unlimited acess to them? It did say that Tetras that are out of play will be used to supply the loading station, but it never said how much each station has. If it does say somewhere, abuse me as much as possible for my bad reading skills.
Unread 08-01-2005, 17:00
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Re: How many tetras?
From 3.3:
"Forty Tetras of each color will be available for each match. Two special Vision Tetras of each color will also be used in the match."
Unread 08-01-2005, 17:01
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
I think it said totoal is 40 for each side im not sure how that is split between the auto load and the human player station.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 08-01-2005, 17:04
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
One Question: Couldn't you just call up your dad?
Unread 08-01-2005, 21:11
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Well, already said, there's 40ea color.... and yeah, if they are outside the field, they will be put back into the loading stations for use.. so it's sorta "unlimited" provided there's tetras left to keep putting in the load station.
But... what about this question - will the loading stations try to be maintained such that there's roughly equal tetras at each one...... or let's say I use up all the auto side tetras, and have 15 on the HP side... will they split them, or do you now just have to get them from the HP side?
I'm assuming the field attendants won't be running back and forth to maintain equal counts on each side...
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 08-01-2005, 21:35
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
there are 11 per team for manual loading and 2 vision and 2 hanging so per alliance there are 37 of their colored tetras. the auto maited loading im still not sure how many that is but it is only a few and i dont think its unlimited
Unread 08-01-2005, 21:48
AmyPrib's Avatar
Where did you find this information of 11 per team? The manual states 40 tetras of each color...
I believe that would include the two of each vision tetras and the two hanging (colored) tetras at the start of the game. It says that if those hanging ones are not displaced in auto, they will be removed from the field when it's safe... But then I'm assuming they are put into play like normal (it doesn't clearly state that though, I don't think)... If you displace it during auto, it stays in play just like normal.
I would think they would split the 36 tetras per alliance (not on the field already) between the HP and auto load zones... seems logical to me..
Unread 08-01-2005, 22:11
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Why waste cell phone minutes? Hes in NH right now, Im still in Va.
Thanks, that should help us, although Im not sure if well even end up using all 40.
Unread 08-01-2005, 22:44
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I'll save you the cell phone minutes (since I have to pay for them)
40 Tetras of each color. About half on the manual loading station side, about half on the automated loading station side. The intent is to keep both sides of the field in a state of "constant supply" so neither the human players hands nor the automated loading stations are ever empty. The field attendants will attempt to keep an appriximately even distribution of tetras between the two side of the field. Based on the initial esitmates, neither side should ever run out of tetras during the course of a match. If necessary, the field attendants may move some from one side to the other if one side is becomming heavily depleted.
Unread 08-01-2005, 22:58
AmyPrib's Avatar
That's great! I wouldn't have expected or assumed that, but that's good to know... Thanks!
RE:Removing Tetras matt111 Rules/Strategy 40 12-01-2005 12:48
Basic Game Breakdown Levin571 General Forum 34 08-01-2005 23:35
Manipulating tetras from the ground. Petey Rules/Strategy 4 08-01-2005 23:19
Knockin of tetras NoRemorse Rules/Strategy 11 08-01-2005 22:48
