Go to Post Many of us are engineers who value precision and accuracy in communication. Words mean things. - Alan Anderson [more]
Unread 08-01-2005, 19:27
Sidney San Martín's Avatar
Sidney San Martín Sidney San Martín is offline
FRC #0555 (Montclair Robotics)
Sidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura about
RS-232 TTL Board?
We're inventorying and even our electonics expert has no idea what this part is. I can only find it in the checklist. Any ideas?
Unread 08-01-2005, 19:31
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: RS-232 TTL Board?
If you look at Innovation first's website...here You'll see a pic of the TTL converter in the upper right on top, its a small part! Hope that helps...
Unread 08-01-2005, 19:32
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
It is used to connect the camera board to the RC. Read the camera documentation for more information.
<edit>
Oh, you meant what it looks like, and where to find it? It's in the bag with the IFI camera board (not the camera itself). It's the piece of PCB about the size of a nickel.
</edit>
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Phil Roth Phil Roth is offline
#0011 (BASF)
Phil Roth is an unknown quantity at this point
Send a message via AIM to Phil Roth Send a message via Yahoo to Phil Roth
I think this board plugs into the cmucam2 video board which only has TTL comm. The little converts TTL to RS232.
Learn more about the CmuCam2 @ http://www.seattlerobotics.com/image...am2_manual.pdf
It's a really cool device and very easy to use. Good Luck
Unread 08-01-2005, 19:37
Thanks! We saw this. One other related question, then - what is the tiny board that goes with it?
Unread 08-01-2005, 19:41
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
It IS the tiny board (as I said, about the size of a nickel). The larger board is the IFI camera board, the one that you plug the CMU camera into.
_
Unread 08-01-2005, 19:43
Right
EDIT: Just saw this in Doug C's post... Sorry!
Unread 08-01-2005, 19:49
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
Simple Explanation here...
The purpose of that board is to convert voltage levels.
Standard logic levels for ICs and small devices is 0-5v, like the RC or OI.
However, when transmitting data over a wire, it is nice to have more noise margin,
and one way to achieve this is to jack the voltage differential. RS232 voltage levels
do just that.
Your standard legacy pc has a serial port that uses RS232 voltage levels, whereas
the RC has a TTL level serial port. I built one of those modules last spring
to interface the edubot to a matrix orbital lcd screen.
The link below has more detailed information.
http://www.beyondlogic.org/serial/serial.htm#1
I assume, w/o having access to a kit right now... that the rs232->ttl converter
is just a max233cpp chip or equivalent with appropriate connectors.
The digikey part number for that chip is: MAX233CPP-ND
The datasheet is: http://rocky.digikey.com/WebLib/Maxi...u%20MAX249.pdf
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
Unread 08-01-2005, 22:46
Thanks for this information. I'll be looking at it in much more detail later.
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Shelf and board dimensions still don't add up kmcclary Off-Season Events 12 20-10-2001 09:12
