iv just been reading through the manual and i don't exactly get what special stuff we need to do to our robot in order for the whole pressure pad thing to work.
Re: question on the pressure pad sensors
your human player has to be standing on it for your robot to work; if he/she gets off the pressure pad your robot is disabled until he/she gets back on the pad.
nycpunk, I'd assume not (that you'd have to do anything special) since they have a connection to your robot controller (they can override you at any time). If that was the case, they would not be able to disable your robot for penalty infractions that require it.
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Translating pressure sensor readout into actual pressure | Mercutio | Pneumatics | 0 | 13-02-2004 16:29 |
| pressure sensors | archiver | 2001 | 0 | 24-06-2002 02:15 |
| Need help with 255 Variable | Joseph F | Programming | 18 | 26-02-2002 14:49 |
| Question about Pressure Switch | Randy_Ai | Technical Discussion | 1 | 30-01-2002 18:29 |
