Re: Tetrahedron Connectors
If anyone needs a MasterCAM file to mill them, I just finished up creating one, just PM me and I will email it to you, I am just going to check it against the real thing tomorrow to verify accuracy then it will be good to go.
Okay, this sounds really dumb, but.. MasterCAM? Huh? |
MasterCAM(The company that produces this software is one of our coporate sponsors.) is a CAD/CAM software that allows you to cut parts using a CNC Machine. For more info go to www.mastercam.com
The FRC Documentation web-site includes a pdf drawing for Field Element TH Connectors:
http://www2.usfirst.org/2005comp/Dra..._CONNECTOR.pdf The material call-out is: .098 CRS ZINC PLATE This does not appear to be a standard sheet metal gage - it's in between U.S. 12 and 13 gage. I'm sure either of these standard gages would work. Is anyone thinking of getting a bunch of these die cut or laser cut in large quantities? |
We didn't get ANY tetra clovers in our kit, because they didn't even ship the black box that came with ours. So we're out of luck until we figure out how to make some of our own. That's better than waiting until Thursday for the box to arrive.
#7
we could mill them or possibly use our mold injection, but i tihnk we are just going to make them out of 16-22 gauge sheetmetal...much much cheeper...maybe not as strong, but being metal it won't break, just bend if it gets bashed around.
#9
You can download the file off the CD white papers here |
#10
We just made the Tetra connectors from 1/8" HDPE sheet we had leftover from the top of the ramp of Stack Attack. Took one from the kit, traced it and cut it out using a band saw and some tin snips. They work great.
(I believe that the connectors you can get from Innovation First are metal for use with the goal tetrahedrons.) -Mr. Van Coach, 599 |
| PWM Style .100 pitch Male Connectors | BrianBSL | Electrical | 2 | 05-10-2004 19:43 |
| shaft connectors | gail | OCCRA | 1 | 25-10-2003 16:07 |
| Slip connectors (custom electrical connectors) | Damian Manda | Electrical | 2 | 08-02-2003 17:53 |
| RJ-45 connectors, DB25 connectors and the like: legal or no? | Andrew Wyatt | Technical Discussion | 6 | 04-01-2002 22:53 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
