Go to Post I have no defined complaints, and I have no solution. I simply have mixed feelings. - Andrew Blair [more]
Unread 09-01-2005, 00:14
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Re: Tetra Rods Steel, not PVC?
According to my dad, who was at the Manchester Kick Off they say to use PVC with threaded rod running through it to gain the weight, apparently the ones FIRST uses are of a different material that is denser then the PVC conduit, but much more expensive and not easily obtainable. So instead they give you the low cost version not the real deal.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
which is better aluminum or steel???? SCYTE16 Kit & Additional Hardware 50 24-11-2005 13:35
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
Goal...PVC is loose... archiver 2001 7 23-06-2002 22:38
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
