Go to Post Because it's a fun challenge. Kind of like Sudoku, but with lexan and evil geniuses. - nathanww [more]
Unread 09-01-2005, 00:31
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Tetra Math
Not that you all couldn't figure this out on your own, but I'll spare you the effort:
For a tetrahedron with side of length x:
distance from midpoint of one side to opposite corner of same face (base altitude): sqrt(3)*x/2
distance from midpoint of one side to the horizontal center of the tetra (below the top point): sqrt(3)*x/6 (1/3 total length of base altitude)
distance from any base point to the horizontal center of the tetra (below the top point): sqrt(3)*x/3 (2/3 total length of base altitude)
height of tetra: sqrt(2/3)*x
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 09-01-2005, 00:33
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
Re: Tetra Math
does anyone know how many tetra's can be fit under one of the goal by any chance?
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
Unread 09-01-2005, 00:40
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Tetra Math
A lot of it depends on how they are stacked and whatnot. Because they could be stacked like they are on the top, but they can also just be pushed in next to each other. One person will post one number only to have 4 other people post 4 different numbers. Though I think your best bet on getting more of them under there would be stacking them. Also, without stacking and just looking at the dimensions, you should be able to fit four COMPLETELY inside and flat on the ground within a singel goal. Please note that the scoring objects do not have to be completely within the goal to count though. It will count as long as it breaks the plane of the goal and it is not supported by the carpet outside the goal or a robot.
See you in DC!
Unread 09-01-2005, 00:42
Eugenia Gabrielov's Avatar
Eugenia Gabrielov Eugenia Gabrielov is offline
Counting Down to Kickoff
Eugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond repute
Re: Tetra Math
However, keep in mind that in order to stack tetra's under your goal, it takes more time to obtain them and manuever your arm to make it perfect then it does with stacking them on the goal (same amount of effort) and also you get more points for stacking and owning. Containing gives you 1 points each, if I am correct in remember stacking gives you 3. Before desigining your robot, remember that some point values are crucial in a game with such close balances of points.
Northwestern University
McCormick School of Engineering 2010
Computer Science
Team 461 for life!
Unread 09-01-2005, 00:43
n0cturnalxb n0cturnalxb is offline
AKA: Shirley
#1159 (Ramona Rampage)
n0cturnalxb will become famous soon enoughn0cturnalxb will become famous soon enough
Send a message via AIM to n0cturnalxb Send a message via MSN to n0cturnalxb
Re: Tetra Math
Considering the goals (aside from the center one) are about 5'3" = 63"(.. that's almost as tall as I am! .. ugh, I feel short now) and each tetra is 2'4" = 28" ...
Let's say each tetra raises the stack about 3"?
And you need about 28" clearance left to fit the last tetra in ...
4? That doesn't sound right. 7ish-9ish?
I think I just fried my sleep-deprived brain.
(edit) Err, cross that out .. I mean around 4-6 maybe per stack.. maybe.. assuming each tetra raises each stack 3". I think. Someone check my math or logic or something, brain's not working well right now..
Assuming you can fit 4 perfect stacks of 4 inside the goal, that's 16.
I'd say go with stacking on top of the goal.. go for containing if you're having a lot of problems with designing the arm, but stacking will give you three times the amount of points you can get by containing .. and the possibility of making a row.
zip ties and duct tape: the answer to all of life's problems
Unread 09-01-2005, 12:21
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Tetra Math
According to the kickoff, each tetra raises the stack approx. six inches.
www.metalmoose.com
Unread 10-01-2005, 00:08
sojouner06's Avatar
sojouner06 sojouner06 is offline
None #0294 (Beach Cities Robotics)
Team Role: Student
sojouner06 has a spectacular aura aboutsojouner06 has a spectacular aura about
Send a message via Yahoo to sojouner06
Re: Tetra Math
one tetra added to the goal is a height increase of exactly 3.5 inches. Therefore, if you just add about 5 tetra's, thats about another foot and a half. So if you have an arm, you would need to have a 10.5 foot at full extension to out class other arms
Unread 10-01-2005, 00:11
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Tetra Math
Where did you get that? From pictures (and according to Dillon Compton) it looks much closer to 6" per tetra.
Team 1257
Unread 10-01-2005, 00:12
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Re: Tetra Math
It is 6 inches per tetra...this is comming from someone who's seen them built and stacked on eachother.
Unread 10-01-2005, 00:14
sojouner06's Avatar
Team Role: Student
Re: Tetra Math
i calulated using a formula i learned in statistics, the width of the pole vs height/ complicated math suff
Unread 10-01-2005, 00:15
sojouner06's Avatar
Team Role: Student
Re: Tetra Math
pole=pvc pipe
Unread 10-01-2005, 00:19
sojouner06's Avatar
Team Role: Student
Re: Tetra Math
i made tetra's too and did see that it was 3.5, ill go see if the tetra's was built properly
Unread 10-01-2005, 01:54
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
Re: Tetra Math
sojouner06, try to edit your posts instead of creating new ones.
ftp://67.170.35.253/robotics/Posting.swf
Anyways, did you take into consideration about the end-caps. Also, when looking at the sidelines during the kickoff, it looked more like 6 inches.
Elknise
Issaquah Robotics
Unread 10-01-2005, 01:58
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
Re: Tetra Math
I thought that the tetras used at the actual competitions don't have PVC endcaps but instead have flat pieces that screw into the PVC?
Unread 10-01-2005, 02:05
REVving up for a new season
FRC #2848 (All-sparks)
Re: Tetra Math
i was in manchester and saw the offical ones and adding them ontop of each other adds SIX inches....i also tested the how many fit under a goal and 7 perfectly stacked will make it as long as there are no tetras ontop of the goal. if there is a tetra ontop of the goal then you can only fit 4 under
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Electromagnets to pick up tetra? xxerin Rules/Strategy 26 10-01-2005 07:30
White Paper Discuss: 296's CORDIC Math Library CD47-Bot Extra Discussion 5 28-04-2004 20:01
Math project edomus General Forum 4 01-04-2004 13:12
Logical statements or math formulas Manoel Programming 1 16-02-2002 23:29
