Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 09-01-2005, 01:54
Sidney San Martín's Avatar
Sidney San Martín Sidney San Martín is offline
FRC #0555 (Montclair Robotics)
Sidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura about
Re: 1 Clippard Tank ???
<R90> There is no limit to the number of solenoid valves, air cylinders, pressure regulators, and connecting fittings you may use on your robot…
Confirmation from the rules. No limit, as long as the team supplies the cash (or the old robot parts).
EDIT: Also, the pneumatics section of the flowchart says that we can use the pneumatics order form or old robots
Has 6 wheeled designs surpased tank treads Andrew Schuetze Technical Discussion 60 27-04-2005 17:29
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
pneumatics tank archiver 2000 2 23-06-2002 22:43
