Go to Post You can either suck up a lot of oxygen, or you can contribute to our communal knowledge. The choice is yours. - dlavery [more]
View Poll Results: Most Important Game Aspect of '05?
Autonomous Mode 18 13.33%
Tetra Capping 102 75.56%
Defencive/Blocking 14 10.37%
Tetra Herding (underneath goals) 1 0.74%
Voters: 135. You may not vote on this poll
Unread 08-01-2005, 23:21
leo_singer's Avatar
leo_singer leo_singer is offline
#1111 (Seahawks)
leo_singer is an unknown quantity at this point
Re: Most Important Game Aspect of '05
Here's the breakdown:
Maximum possible team score: 216 pts
A. Stacking a tetra:
3 pts / 1 tetra, up to 40 tetras * 3 pts = 120 pts
B. Putting a tetro inside a goal:
1 pts / 1 tetra, up to 40 tetras * 1 pts = 40 pts
C. Scoring a vision tetra on one of the outside middle goals:
6 pts / 1 tetra, up to 2 vision tetras * 6 pts = 12 pts
D. Scoring a vision tetra on the center goal:
9 pts / 1 tetra, up to 2 vision tetras * 9 pts = 18 pts
E. Scoring one row of tic-tac-toe:
19 pts / 3 tetras or about 6 pts / 1 tetra
F. Scoring two intersecting rows of tic-tac-toe:
24 pts / 5 tetras or about 5 pts / 1 tetra
(Note: tic-tac-toe gets you up to 107 pts / 9 tetras or about 11 pts / 1 tetra, if you get every possible row)
G. End zone:
10 pts / 3 robots, which we'll say is equivalent to about the same level of effort as 3 pts / 1 tetra
This list doesn't take into account the magnetically suspended tetras and many tic-tac-toe configurations.
Clearly, tic-tac-toe can give you the most bang for your buck, but not always. Tic-tac-toe in items E and F are only worth two stacked tetras.
It looks like A will be the most straightforward way to get most of your score, but C and especially D can make a big difference. But G can also decide a match. For that matter, any one of A through G can easily decide any match.
Although A is not the most efficient way to score, it is probably the most feasible way to score a lot.
Unread 09-01-2005, 00:05
Alex Pelan's Avatar
Alex Pelan Alex Pelan is offline
GO IRISH
FRC #0177 (Bobcat Robotics)
Alex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant future
Send a message via AIM to Alex Pelan Send a message via Yahoo to Alex Pelan
Defense and herding are key here. I think we are overestimating the amount of teams that will be able to reliably cap multiple tetras. Think about how long some teams took to cap last year, and then add more edges/having to be perfectly aligned with the top of the goals. Thus, in many matches, especially in the earlier rounds, while some teams that did not get much driver practicing in are getting used to their robots still, there will not be much capping going on. However, herding tetras into goals will be a lot more feasible, and, if there is nothing stacked on top, you can still make tic-tac-toes with tetras in the goal for extra points. Manipulating the tetras is not going to be an easy task. As for defense, it is always integral to the game. All robots should be built hardily and should be able to effectively block other robots. Control of the center, whether it be through capping or herding, will be key here, and we should see a lot of last minute shoving matches here, where capping the center can result in many-point swings.
Team 177 - Bobcat Robotics (2004-2007)
University of Notre Dame Class of 2011
Unread 09-01-2005, 00:14
richardp's Avatar
richardp richardp is offline
Heidi's Minion
AKA: Lil' Richie
FRC #0116 (Epsilon Delta)
richardp has a spectacular aura aboutrichardp has a spectacular aura aboutrichardp has a spectacular aura about
Send a message via AIM to richardp
As I read the rules i beleave that it says that u get points just for haveing a tetra on top it doesnt have to be the top on it just has to be on. I could be wrong ill check with Dave tomarrow. But i think the most important aspect is just being able to get the tertas-themselfs ask fast and effeciently as possible so that they are there to use.
Unread 09-01-2005, 01:42
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
None of the above.
Tetra manipulation. Plain and simple.
Although, if it had to be one of those choices, it would be tetra stacking.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 09-01-2005, 01:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
every tetra you get onto a goal counts as points for you.
It has to be on top to count as a row though
2001-2004: Team 100
2006-Present: Team 254
Unread 09-01-2005, 02:03
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
I'm wondering if what wins football games will end up being the factor in winning a robotics match. Using defense in many ways could assist teammates as they cap, go for the tic-tac-toe, etc. I am expecting the final moments of the game to be intense, and my money is that a robot with serious shoving power teamed up with bots with other capabilities will be a lethal combination.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 09-01-2005, 02:06
unapiedra unapiedra is offline
FRC #1520
Team Role: Student
Rookie Year: 1990
unapiedra will become famous soon enoughunapiedra will become famous soon enough
I think the biggest problem is going to be the 3+3 Teams. This forces the teams extremely to work together and to dependent.
For me the most important point is that the robots have to be universal in the design but run specific tasks during the competition.
Unread 09-01-2005, 07:38
n0cturnalxb n0cturnalxb is offline
AKA: Shirley
#1159 (Ramona Rampage)
n0cturnalxb will become famous soon enoughn0cturnalxb will become famous soon enough
Send a message via AIM to n0cturnalxb Send a message via MSN to n0cturnalxb
Why do we keep saying tic-tac-toe? It reminds me of bingo, but with 3 per row
I think the stacking's one of the most important aspects. If you can get your robot to hold the tetras relatively stable-y AND stack while collecting (go in and out of the loading zone, collecting more than one tetra and forming a stack before you put it onto the goals) ... you've got a pretty good advantage there.
Then again, they're pretty heavy to keep holding.
And I have no idea how such an arm mechanism would work.
.. But anything's possible!
zip ties and duct tape: the answer to all of life's problems
Unread 09-01-2005, 15:38
rcflyer620's Avatar
rcflyer620 rcflyer620 is offline
Advisor, BAA board member
AKA: Mark Eastman
FRC #2199 (Robo-lions)
rcflyer620 is an unknown quantity at this point
Originally Posted by Cyberguy34000
What do you think?
Because of the initial height of the center goal I think capping will only be important there for 2 or three tetras. Beyond that, the weight and size limits of the robots and the weight of the tetras will not allow an articulated arm or lifting platform to get high enough to put any more on. What if you were the first one to cap the center and then defended it vigorously while completing rows?
Unread 09-01-2005, 16:15
MikeWherley's Avatar
MikeWherley MikeWherley is offline
MikeWherley is on a distinguished road
Send a message via AIM to MikeWherley
Originally Posted by Kyle
thats what i was thinking that Dave and the rest of the design committee must have gotten really stressed trying to think of a new game and decided to play tic-tack-toe and then it dawned on them, "this could be a great game but first we have to make it extremely complicated and with stuff no one has worked with before." or maybe they just thought of a cool game and it just happened to be similar to tic-tack-toe. i think the most important part of the game is what you do in auto mode.
I think that the game is more a combination of Tic-Tac-Toe and Othello. The combination is very easy to understand and play, but very hard to win, and lots of strategies available, some of which are actually going to win!!
Unread 09-01-2005, 16:34
occra 23.
AKA: ryo
None #1481
really? i would think capping tetras would be easier than big balls assuming you have a reliable method of lifting a heavier tetra. and you can cap from any direction not only one side. and if you get the goal tetrahedron tip anywhere inside the bottomside triangle frame of a tetra , you just drop and itll stay.
Unread 09-01-2005, 16:35
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
tic-tac-toe and being able to cap
First you need a robot that can cap
Second to have the strategy to make the tic tac toe
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 09-01-2005, 16:41
bigjhutch bigjhutch is offline
AKA: James Hutchins
#1648 (Gearbox Gangstas)
bigjhutch is an unknown quantity at this point
No Question,
Tetra capping is harder, but it's unreversable and how many points can you score in autonomous mode? If any robot scores more than three single handedly, I will marry that robot.
Unread 09-01-2005, 17:52
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
The most important thing to me is capping the center goal in autonomous mode with the vision tetra. Once that one is capped during that time you get 2 tetras placed on your goals, at that point you then have control of 3 goals and easily can make a row by capping your own goal in the middle against the wall.
Unread 09-01-2005, 18:25
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
I don't think I understand that comment. You don't get a "row" unless it's stacked on top.. You can't get a row using a tetra just sitting underneath a goal.
Maybe I just mis-read your comment....
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Least Important Aspect Steve Howland Rules/Strategy 10 21-04-2004 20:28
Most Important Aspect of Game? Jeremy L Rules/Strategy 36 08-04-2004 14:11
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
