Go to Post "The rio has a boulder sized hole though it? *shrug* Just duct tape it. That doesn't let the code out, right?" - Bkeeneykid [more]
Unread 09-01-2005, 01:13
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
Re: Electromagnets to pick up tetra?
Actually, an electromagnet probably wouldn't adversly affect the robot controller. The controller is designed entirely using solid state devices (no magnetic storage), so it should be immune to any magnetic field that could be generated by a FIRST robot.
Team 518 Home Page
Unread 09-01-2005, 01:49
Racer26 Racer26 is offline
I'm pretty sure Dan is correct... An electromagnet wouldn't hurt the controller... think about all your motors... CIM's in particular... they generate a HUGE EMF field (we were messing about with a compass one year and they messed it up)... but they dont hurt the controller, even when placed side by side. I'm pretty sure magnets are harmless to the controller.
Unread 09-01-2005, 02:15
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Per the 2005 Part Use Flow Chart, from page 14 of Section 5 The Robot, electromagnets are not allowed.
Originally Posted by Al Skierkiewicz
An electromagnet is by definition a solenoid, i.e. a coil of wire, wound around a form, that induces a manetic field by the introduction of electricity, to attract another metalic object.
Wetzel
Unread 09-01-2005, 02:41
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
even if the magnets are completely harmless, the only metal on the tetras are the bolts. an electro magnet would use power, and a regular magnet would present the problem of getting stuck to other robots. there is definitely a possibility of a megnet being used (if legal), but just make sure you design the mechanism good
Unread 09-01-2005, 03:17
xxerin's Avatar
xxerin xxerin is offline
#0973 (Greybots)
Team Role: Student
xxerin is an unknown quantity at this point
I think an electromagnet on the arm may be able to be pulled off(providing its legal) but its just not practical.
If it dosen't work, use a bigger hammer!
Unread 09-01-2005, 04:45
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
There shouldnt be anything in the robot controller that could be dammaged by a magnet. The data in the controller is stored in an EEPROM which you have to access through a serial connection in order to erase. Thats what I think at least. What I know is that they designed the field with magnets in it, and plus, I have personally run a chiwopuha motor (electromagnets make motors go) on top of a robot controller just to make sure nothing happens, and it doesnt.
Unread 09-01-2005, 06:07
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
In any event:
Wetzel
There's not much more discussion to be had on the topic.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 09-01-2005, 07:53
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by Mouse
Didn't the construction manual show them being made out of a sort of plastic material?
The models at our area were made out of metal though...
Maybe I'm mistaken?
The small, scoring tetras are made of plastic (PVC). The larger goals (which you place the tetras on top of) are constructed of metal. There was a few changes relatively close to kickoff (apparently), so maybe your kickoff site or whatever used slightly outdated instructions.
Unread 10-01-2005, 02:56
vtrehan's Avatar
vtrehan vtrehan is offline
Mentor - Controls & Programming
AKA: Vivek Trehan
FRC #1241 (Theory6)
vtrehan is on a distinguished road
Send a message via Yahoo to vtrehan
The first thought in my after watching the videos was electromagnets, but now i am pretty certain its not the best way to go. Mainly because it will draw too much current and drain lots of power (snatching it from the motors), the electronic noise it will create has to be monitored using some H-bridges or something similar to save the motors, because it will hurt that for sure, thus increasing needless complexity. Also the magnetic grip wont be as powerful as you want it to be.
It would be pretty cool if some teams could actually use it effectively, so good luck to them.
Vivek.
2006-GM Industrial Design Award - Greater Toronto Super Regional
2006-Engineering Inspiration Award - Arizona Regional
2006-Regional Finalist - Arizona Regional
2005-Best Defensive Robot - Wonderland Off-Season
2005-Regional Chairman's Winners - Greater Toronto Regional
2005-Regional Champions - Waterloo (Thanks 68 and 1305)
2005-Best Website - Greater Toronto Regional
2005-Team Spirit Award - Waterloo
2005-Entreprenuership Award - Waterloo
2004-Rookie All-Star award - Great Lakes Regional
2004-Rookie Highest Seed - Greater Toronto Regional
2004-Rookie All-Star award - Greater Toronto Regional
2004-Team Spirit award - Greater Toronto Regional
2004-Team Spirit award - National Championship
Unread 10-01-2005, 03:44
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
Post Re: Electromagnets to pick up tetra?
Originally Posted by xxerin
I was wondering if we could use an electromagnet to pick up the tetra?
the FIRST tetras will not have bolts, they will be glued together in some manner, so far as i was informed.
Unread 10-01-2005, 04:57
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
whilst they wont pick up the tetras, they could be useful in that you could hold the tetra in teh game by using an electromagnet to close a grip, but also when you turn the power off, the electromagnets will also go off and iwll fullfill the part of the rules for "you must be able to remove a tetra from
a robot which is deactivated"
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 10-01-2005, 07:30
nekura
#1288
"Per the 2005 Part Use Flow Chart, from page 14 of Section 5 The Robot, electromagnets are not allowed."
the further discussion of this topic is futile.
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
How does your team pick presidents/ captains? Marygrace General Forum 30 29-04-2003 22:37
Top seeds pick.... archiver 2001 6 23-06-2002 23:12
When does FIRST pick the game? archiver 2000 9 23-06-2002 22:08
Sponsers: Whats the best way to pick THEM up? Wetzel Chit-Chat 2 06-05-2002 22:32
How many balls can you pick up?????????? CMC General Forum 6 14-02-2002 21:40
