Go to Post Being the GDC is not an easy job, anything can happen. Lunacy happened ::rtm:: - Conor Ryan [more]
Unread 09-01-2005, 10:15
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Restricted to the Anderson Connectors in the Kit?
Is it still legal to use two connectors in parallel, for increased capacity and failure resistance?
Thanks,
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 09-01-2005, 10:28
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Thanks,
You would have to ask FIRST that question on the FIRST Q&A
Unread 09-01-2005, 10:57
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
I asked Dave Lavery this same question at kickoff... his reply was something like this:
[paraphrase]
Those Connectors can handle 120amps for short periods of time... (i assume he meant about a match length)
The problem was when people were using aligator clamps to connect to the amp connector and scratching the mating surfaces, which was causing a poor connection and the 'connector failure'.
You may not use alternatives, especially because of the modified weighting rule this year. (120lbs + battery and leads).
[/paraphrase]
I also, about 2 years ago asked about the 6awg wire. Yes the voltage drop per foot isn't ideal as good as say 4awg...but apparently the insulation is rated for that current. (That is, insulation on wires has a temperature rating before it melts...) You can read about it on belden's web site...
So the real issue here is: Is the 6awg wire in the kit have insulation rated
for 120A? (To which I don't have an answer.)
Also I believe FIRST relies on the fact that matches are short and most teams don't draw 60A continuous.
I'm still uncomforatable with it, I'm big on following ratings for electrical supplies based on the worst case situation and not on the usual happenings.
I don't write the rules, I just complain about them...
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
