Go to Post No, nothing secret unless you include the following: will it work?, can it be driven and will it release the balls. - twolf [more]
Unread 09-01-2005, 11:59
Deltafrog Deltafrog is offline
AKA: Andreas Stump
#0469 (Las Guerrillias)
Deltafrog is an unknown quantity at this point
Single Tetras at Beginning of match?
<G04> At the discretion of the alliance, one (and only one) TETRA may be in the possession of one ROBOT in
each alliance at the beginning of the match. The TETRA must be completely SUPPORTED by the ROBOT,
not in contact with either the floor or any field element, and the ROBOT – including any MECHANISMS
designed to hold the TETRA – must still satisfy the volume starting constraints specified in <G01>.
Does this mean each alliance get's one tetra at the beginning of the match?
21 Frogs sitting in a tree R O C K I N G...
Unread 09-01-2005, 12:07
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Tetras at Beginning of match?
You get to take a tetra, and give it to one of the robots on your alliance. Then if you have some autonomous code to cap a goal, you'd be able to pick up some points in autonomous while the rest of your team does other things.
Unread 09-01-2005, 12:10
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
in the videos at kickoff it shows the tetra only on the robot that starts in the middle spot, the tetra can be given to anyone of the robots as long as it goes along with all the rules.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 09-01-2005, 12:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
However, in the picture in the manual it looks like the Tetra must me fully contained in the starting volume. Is this true or no?
Unread 09-01-2005, 12:25
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
That's what I read in the rule. Must be within your starting volume.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 09-01-2005, 12:30
What picture are you referring to? Rule G04, which was posted above, states that the ROBOT must be withing the starting constraints, but doesn't say the Tetra has to start within the constraints.
In other words, you can't extend your arm to be able to hold the tetra, but if you can grasp it from your starting position, you're ok.
One question I have is will the robots be able to be powered on before the match in order for it to grasp the tetra, or does it need to be a passive device?
Unread 09-01-2005, 12:48
AmyPrib's Avatar
You know - after re-reading G04, better this time, the sentence is:
"The tetra must be completely supported by the robot, not in contact with either the floor or any field element, and the robot - including any mechanisms design to hold the tetra - must still satisfy the volume starting constraints specified in G01.
So, now I read it as... so long as your mechanisms holding the tetra at the start of match is within your starting volume, then you're ok. The tetra itself does not need to be within that volume.
I mis-read it the first couple times....
Just where are vision "bonus" tetras placed? David Brinza Rules/Strategy 17 10-01-2005 20:50
Basic Game Breakdown Levin571 General Forum 34 08-01-2005 23:35
NASA/VCU Last Moments in Final Match Munkaboo Regional Competitions 19 09-03-2004 12:21
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
