Go to Post Honestly, I can't understand why anyone wouldn't want to be a mentor. The fools don't know what they are missing. - Steven Smith [more]
Unread 08-01-2005, 16:48
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Sensor Warning-Lighting is not created equal
Please make sure you recalibrate your CMU sensors whenever you switch from differnt lighting schemes. Anyone who has taken photography knows that diffent lights will actually cause a color shift. Not correcting this colorshift will result in an inaccurate representation of colors which is interesting to talk about in another topic because there is contraversy as to what color Mars is. Flourescent light usually has a green tint, halogen results in a redish tint, and I don't know what sunlight does.
Unread 09-01-2005, 00:32
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Re: Sensor Warning-Lighting is not created equal
ah. that'll be nice to know.
thanks!
~Stephanie
(and thanx the rest of our programmers down here too)
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 09-01-2005, 01:12
Enterprize's Avatar
Enterprize Enterprize is offline
Ubergeek
AKA: Joshua
#0269 (Cooney Robotics)
Enterprize has a spectacular aura aboutEnterprize has a spectacular aura aboutEnterprize has a spectacular aura about
Send a message via AIM to Enterprize
Thanks for the "head's up"!
Unread 09-01-2005, 01:20
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
I had a hunch this new sensor sounded to good. I have not seen it yet, is it diffucult to calibrate or is it possible to progam it for a range of many shades?
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 09-01-2005, 12:15
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
scottm87 is on a distinguished road
You would be suprised how much the CMUCam already has integrated into it. Calibration routines are automated, and there is a fair amount of documentation on the site on how to deal with different lighting conditions. The camera routines that would are dependent upon the lighting conditions are integrated into the camera for the most part anyways.
In short, I think that the lighting will be less of a problem than everyone is making it out to be. Because so much of the camera interface is high level results of very complex, optimized, and tested machine vision routines, I think you will find the output that actually arrives to your robot is pretty clean as long as the lighting is fairly even and bright enough to illuminate the field.
I haven't tested it though with the IFI routines, so I don't know. I have, though, seen a CMUCam in action and was very impressed.
Unread 09-01-2005, 12:33
When you initially set the camera, you must calibrate it to find what the RBG value sets of the objects you are trying to find. Then, you take the three values, Yellow, Green, and Red, and copy them into the "camera_init()" function in the user_routines_ddt.c file. This is, of course, if you are using the code supplied by IFI. I highly suggest you use this code, making modifications to it as needed.
When you turn the camera on, it will auto detect lighting conditions, and adjust the AEC (automatic exposure control) to compensate for this. In easier terms, it sees how much the light is "grayed" compared to set code values. If it is darker, it allows more light to enter the camera before taking a frame, and vice versa.
Unread 09-01-2005, 12:44
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
IF this turns out to be a big issue, you will need to be careful calibrating at the event. Usually, the pits are lit by venue lighting, normally HID, which has much more blue in it. However, the field is normally lit with theatrical lighting, which is a tungsten source, and has much more red in it. I do not think this will be much of an issue though, as you are looking for the three primary colors (plus yellow). The camera should be able to discern between these colors, even if the calibration is off by a little.
Unread 09-01-2005, 17:51
Adam Y.'s Avatar
Adam Y.
no team (?????)
Ehhh... I was only mentioning this because of personal experience and from what I read about the original CMU cam and as experience as a mediocrae photographer. I have about fifty pictures that are completely washed out in a sickly green because I didn't know that flourescent lighting does this.
Unread 09-01-2005, 17:54
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Funny how we computer folk often forget that yellow, not green, is the third primary color.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-01-2005, 18:30
Alumni of 168
Actually, when referring to light, red green and blue are the primary colors, in Pigment, the three primary colors are Cyan, Magenta and Yellow.
New Website being created ! mtaman02 IT / Communications 25 26-01-2005 03:37
Night scene lighting Lev 3D Animation and Competition 14 30-01-2003 23:43
