Go to Post MORAL: Always wear safety glasses when you're putting on your safety glasses. ;) - Joel Glidden [more]
Unread 09-01-2005, 11:39
Nixterrimus Nixterrimus is offline
AKA: N. Rowe
#0578 (Blue Lightning)
Nixterrimus is on a distinguished road
Send a message via AIM to Nixterrimus
Hall Effect Sensor.
The 2005 kit came with something a Hall Effect Sensor, after a bit of looking I found the manual for it, it's actually a ATS665LSG made by Allegro Microsystems. Allegro desribes it as a True Zero Speed, High Accuracy, Gear Tooth Sensor. What does that mean? Is this the "gyro" for this year? And does this work in congunction with the accelerometer. There are two of Hall Effect sensors so it seems we need to use them in twos. Also the Allegro manual mentions gears and gear tooth length. So I'm a bit confused and a bit curious and maybe even a bit excited. Anybody know anything about the Hall effect?
Unread 09-01-2005, 11:48
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: Hall Effect Sensor.
My GUESS is that you would use these to count gear teeth - used for feedback to determine how fast/far your robot moves, or for sensing the motion of anything else using chain/sprocket. However ours were missing when we did our kit inventory ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 09-01-2005, 11:50
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
scottm87 is on a distinguished road
Okay. A gear-tooth sensor sits in your gearbox and uses a magnetic field in order to sense each specific tooth go by. The Hall Effect is the concept that allows the integrated circuit to take a measurement of the magnetic field surrounding it. (Hall effect compasses are also popular) The amount of time that elapses between the each tooth gives the speed of the rotating gear, which can then be scaled to the speed of the wheel, etc.
This is not a gyro. A gyro returns your angular acceleration (NOT your angular heading... you would need to integrate the acceleration to get that)
Unread 09-01-2005, 12:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Check the Accelerometer bag. They are very tiny things and many teams have found them stuck to the accelerometer so they look like part of it.
Unread 09-01-2005, 12:34
Nixterrimus, Is Ken Wittlief still on your team? He should be able to explain the sensors and demonstrate their usage.
Unread 09-01-2005, 12:40
This is a neat article I found on calculating heading with a rate gyro.
http://www.seattlerobotics.org/encod...onal_gyro.html
Not sure if FIRST provides us with this code though, I'll have to dig deeper into the documentation and report back.
[EDIT] I found this article from a Hall Effect sensor manufacturer about how they work. http://www.micronas.com/products/ove...sors/index.php [/DIT]
Unread 09-01-2005, 12:41
AKA: N. Rowe
No, sadly Mr. Wittlief's son graduated and he isn't a part of the team this year.
Unread 09-01-2005, 12:43
AKA: N. Rowe
Alright so this isn't a gyro, I'm good with that, but is this what was Demoed at the kickoff where the robot was able to correct its position? Does the hall effect sensor return your angular heading?
Unread 09-01-2005, 12:45
AKA: N. Rowe
I looked at that too. Did you think that it was in English?
I thought that a lot of it was out there, I suppose I'm looking for just an intro to the hall effect.
Unread 09-01-2005, 12:48
www.google.com , my friend
Unread 09-01-2005, 12:57
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Gyros measure angular velocity, not acceleration. The first integral of the velocity it the distance, so integrating a gyro provides angular distance, or relative heading.
Using a gyro to measure the robot's heading is pretty common with FIRST robots. The parts teams used last year are the Analog Devices ADXRS150EB and ADXRS300EB. The only difference is that the 150 can measure +- 150 degrees per second and the 300 measures up to 300 degrees per second.
Lots of posts describing how to do it.
Unread 09-01-2005, 15:43
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
I BELIEVE what was demoed at the kickoff (not 110% sure) was the accelerometer. An accelerometer gives back a reading that tells how fast you are accelerating, i.e. changing speed, in a given direction. Using some programming, you can sense when you are moving and take steps to remedy it. A hall-effect sensor uses a magnetic field to detect a metallic presence, and therefore does not return angular headings. I am pretty sure they put out pulses when a metallic presence is detected. It's just an FET, in other words.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 09-01-2005, 16:02
Umm Errr...
To clear things up, the HAL effect sensors have NOTHING TO DO WITH ACCELERATION, OR HEADING. They are a type of sensor that detects the presence of ferrous materias. They are designed to be mounted up against(but not touching) the teeth of a gear in a gearbox or other assembly. They will output 1 pulse for each gear tooth that goes by them. If for example you were to connect them to your drivetrain, you could count the number of pulses they output to figure out how far your robot had traveled. It is also possible to use them to determine the speed at which your robot (or some subassembly) is moving.
1139 Alumni
Unread 09-01-2005, 17:42
AKA: N. Rowe
So this is how FIRST is killing dead reckoning? Hooking these up next to gears tell you how far you've gone, the accelerometer could tell you if you were straight and now we can drive the robot any direction and know exactly how far. Right?
Unread 09-01-2005, 18:01
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
No. To be honest it's still dead reackoning and you still do not percisely know where the robot is with 100% certainty.
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
