Go to Post first post and the FRC "well what is a stick" comes in. Toothpick, does it need to be round, does a carbon fiber chain of Buckie balls count as a stick. CD posters are sooooo predictable. - Foster [more]
Unread 09-01-2005, 12:42
MASherry MASherry is offline
Team Role: Driver
MASherry has a little shameless behaviour in the past
Pneumatic Cylinders
Hey i was wondering what the formula is for how much air is used by the cylinders every time they go in or out?
Carnegie Mellon University Class of 2009!!!
2005- Arizona Regional Champs (Thanks 1492 and 1324)
2005- NYC regional finalists (Thanks 38 and 1660)/ 2005- NYC regional website award
2005- NYC regional J&J Sportsmanship award
2005- National J&J Sportsmanship award
2004- Team Shooter
2004- Crowd Pleaser Award- NYC Regional
2003-7th Place Galileo Divison- Nat's
Unread 09-01-2005, 18:49
FreeBSDboy FreeBSDboy is offline
FreeBSDboy is an unknown quantity at this point
Re: Pneumatic Cylinders
I'm assuming that you want to calculate the pressure drop in your air storage.
Because you have a different pressure and volume in your storage tank from your actuator, you need to calculate the mass of air used.
You need to calculate the mass of air it takes to fill the volume of the cylinder (and all the tubing) using the ideal gas law (PV=nRT or PV=mRT/M more commonly) for the set pressure, then subtract it from the mass of air in your storage tanks (as calculated with the idea gas law). Then calculate the new storage pressure based on the amount of mass left in your storage tanks (again with the ideal gas law).
There should be examples on how to properly apply the ideal gas law in a High School level Chemistry book.
Question on Pneumatic Cylinders RichardBCR Pneumatics 5 25-01-2004 22:46
Custom pneumatic cylinders duckshepherd Pneumatics 7 24-01-2004 20:39
Beatty and Kingman JAlpert Regional Competitions 51 08-04-2002 16:59
servos, chapulas, cylinders and Skyway...in other words... Jessica Boucher Motors 7 14-01-2002 19:36
Pneumatic Cylinders Gary Bonner Pneumatics 1 12-01-2002 08:19
