Go to Post CIMs are NEAR indestructible and I <3 them for it. - Andrew Schreiber [more]
Unread 08-01-2005, 22:56
Billfred's Avatar
Billfred Billfred is offline
One thing to note on the hanging tetras...
I was looking at the field today, especially at the hanging tetras.
I'll tell you now, if you didn't figure it out already (and by looking at the topics thus far, it doesn't look like anyone has)...
  • Putting a tetra on top will make it drop.
  • Giving it any reasonable amount of force on the side will make it drop.
  • A good whack to the goal about midways (like me hitting it with the palm of my hand with a bit of a grunt) will make it drop. (Note that you don't want to break the field, lest the thing that drops becomes your ranking.)
And one other thing about the tetras that may or may not be addressed soon...holding some of them, a loose nut in one piece of the pipe will cause that part to spin around. Know that if you're planning on building a one-pole grabber.
Unread 08-01-2005, 23:20
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: One thing to note on the hanging tetras...
what does that have to do with the nut? are these pvc pipes, or poles?
another thing to note, though might have been said, is that you can't just through them on top, you have to place them as shown in the clips.
I suspect that if you just carelessly put them on top, they might not align easily.
i hope that made sense, it's real early right now, i'm going to prepare our bot for the israeli kickoff (which will be really boring cause i watched the whole thing yesterday )
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 08-01-2005, 23:25
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Try and put a tetra on a goal not-aligned, or carelessly... it's hard to balance it that way, and it takes just the slightest movement to knock it into place.. it'll slide into seated position... this is a good thing.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 08-01-2005, 23:55
Billfred's Avatar
They're PVC pipes, yes. But the tetra-maker plates are held in place by nuts and bolts. They come loose, and the pipe it is attached to rotates.
Of course, you can retighten it (I fixed one with my fingers), but when you've got 80 of the darn things around the field, that may get a bit unwieldly.
Unread 08-01-2005, 23:57
Michael Hill's Avatar
I don't know about giving it a side whack would take it down. They are using some pretty heavy magnets (50 pounders to be exact). That'll be a little bit of force to take down. Nothing that should be too hard however.
Unread 09-01-2005, 00:01
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
On the actual field pieces, the end caps will be glued to the pipe, so it will not rotate. And the bolts should be installed with loctite, so there should be very little chance of them coming apart during a competition.
See you in DC!
Unread 09-01-2005, 00:06
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Mike - I don't recall seeing a 50 lb magnet - I think they hang from something like a 3 lb magnet - it looked to me like the magnet described in the non-encrypted field pieces and parts list released on Thursday. I thought they were called pot magnets or something like that - anyways, I don't think they are 50 lb magnets, but - maybe I missed that.
Unread 09-01-2005, 00:12
Well..the tetras would in no way be able to be held up by 3 lb magnets as they are 8.5 pounds each. I was talking to one of the builders of the field in Kokomo. I asked how the hanging tetras were attached. He said there are 3 washers on the tetras and a 50 lb magnet on the goal.
Unread 09-01-2005, 00:13
Psycho Penguin's Avatar
Psycho Penguin Psycho Penguin is offline
New Rat Pack Captain!
AKA: Nate
FRC #0830 (Rat Pack)
Team Role: Student
Psycho Penguin is an unknown quantity at this point
the magnets are small round disc-shaped magnets that can rotate 360 degrees It doesn't take much force to knock the tetra down
Nate -- Team 830, The Rat Pack
Unread 09-01-2005, 00:14
The pot magnets were listed as 30lbs from one source and 50 lbs from the other.
Unread 09-01-2005, 00:16
I personally think 30 would sound like a better number. 50 seems like it would be an overkill.
Unread 09-01-2005, 00:18
volunteer helper
FRC #6099 (Knights)
Thanks Joe - I missed that.
The hanging tetras weigh about 8.5 lbs (vision tetras weigh more)
so - I suppose that makes sense.
Hope it is 30 lbs. although impacts tend to dislodge magnets even if they are pretty strong.
Unread 09-01-2005, 00:19
I don't know how much impact they will receive since the hanging tetras will only be available in autonomous mode.
Unread 09-01-2005, 12:46
EddieMcD EddieMcD is offline
EddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud of
Extend, turn around, WHACK.
Seems like it'll be quite common for teams unable to get the vision tetras.
Unread 09-01-2005, 13:08
rangersteve rangersteve is offline
AKA: Steve
FRC #0931 (Perpetual Chaos)
Team Role: Student
rangersteve is on a distinguished road
Send a message via Yahoo to rangersteve
I have looked everywhere and can't find out how many points you recieve for knocking off a hanging tetra or for capping with a vision tetra. Does anyone know???
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
hanging Gamer930 Rules/Strategy 7 17-01-2004 18:30
1999....look there for hanging ggoldman Technical Discussion 3 14-01-2004 12:50
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
