Go to Post Life isn't fair. There's always luck involved. Welcome to the real world. :) - Exla357 [more]
Unread 09-01-2005, 12:48
DAN THE MAN DAN THE MAN is offline
DAN THE MAN is an unknown quantity at this point
Atwood motor specs
I am looking for atwood specs for this years atwood motors. i have seen alot from previous years and i need to know for sure that this years will be the exact same. as well i am unsure of what speed to use to do my calculations. i have found out that for out robot to go 5 feet /sec with a 6inch wheel i need to gear down the motor 28:1. can someone complete this calculation for me to make sure i am correct. thank you
dan the man
Unread 09-01-2005, 13:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Atwood motor specs
Check the Guidlines_C.pdf document (Guidelines, tips, and tricks). Strangely this year is lists the free speed a little less and the torque in oz-in instead of Nm. I have not converted it though.
Unread 09-01-2005, 13:35
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Exclamation Re: Atwood motor specs
dan the man
I dont currently have the specs but i will give you some aproximations
well under a regular load the CIM does just under 5000 (something lke 4960) rpms SO:
5000rpms /60 seconds is 83.33 rps which is 41.6 FPS with 6" circumferance whells without a tansmission.
so you equation would be 41.6fps * (gear ratio) = 5fps
that gear ration would be apx 1:8 giving you a speed of 5.2 fps under a normal load remember you need to consider load and amperage when designing a transmission theese atwoods have the potential to draw much much more than the 40amps you are allowed.
(The above is all using the 5000rpm aproximation)
For info on this i suggest you read through :
http://lancet.mit.edu/motors/
it is listed in the FRC manual on page 4 of the robot chapter.
Just as a side note i learned this lesson the hard way last year when we drew 90 amps in a stall and continually popped breakers. Its not fun at all.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 09-01-2005, 13:57
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Small loss of Pi, figures are correct for a wheel with as you say a 6" circumference, that would be 6/3.14 to get diameter, A 6" wheel is 6*3.14.
So 83.33 *1.57' gets 130.8 fps plug that in:
130.8 * (gear ratio) = 5fps and you get 26:1
-Biff
Need Chiaphua, atwood, cim motors!!! falconmaster Off-Season Events 2 07-07-2004 14:32
Atwood Speed help psychoCHIPMUNKK Technical Discussion 2 07-04-2004 07:29
Limit of the atwood motors? Clanat Motors 6 16-03-2004 10:46
Where to get CIM (Atwood, Chiaphua) motors? DougHogg Motors 13 16-12-2003 13:21
Atwood Motor cutout dkeith Motors 3 24-03-2002 19:05
