Go to Post Life can be painfully short and you never know how things could change in an instant. It never hurts to say thank you. - Karthik [more]
View Poll Results: Which setting do you use for the Victors on your drive train?
Coast 7 50.00%
Brake 5 35.71%
We have a switch to control it 0 0%
What? 2 14.29%
Voters: 14. You may not vote on this poll
Unread 09-01-2005, 15:52
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: victor brake/coast setting
Originally Posted by Rickertsen2
We have done this with an array of relays for the last two years and had no problems with inspection. I havn't read the rules carefully enough to see if it is legal this year though.
------------------- Edit --------------------------
It Looks to me like Rule R51 prohibits this sort of thing. There may be a loophole however. I believe that all the jumper does is pull a pin either high or low. there is no rule that i can see that prevents you from directly connecting this pin to a digital output. I wouldn't consider this a "custom circuit". This may be a loophole but i feel it does not go against the spirit of any rules. You are not providing a PWM outpur, not directly controlling movement and not posing a safety rist. BTW I believe the signal pin is the middle one.
This method (direct connection to the controller) was addressed last year in Q and A on the first site, and as I recall was not allowed, The relay method would seem logical even if you have to drive it with a spike. I would suggest spell out exactly how, including a wiring example and submit it to the Q and A process.
Thanks in advance -Biff
setting autonomous mode Allison Programming 10 08-03-2004 20:37
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Need help setting up phpBB on a coolfreepages.com website LBK Rules Website Design/Showcase 5 30-03-2003 20:02
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
Jealousy is setting in now!!!! archiver 2000 5 23-06-2002 23:46
