Go to Post [in response to http://www.welovefirst.com/] I feel like I've just been FIRST Rick Rolled. - kramarczyk [more]
Unread 09-01-2005, 18:08
team222badbrad's Avatar
Happy Birthday! team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Inventor Tetra Connector
Ok I have tried to draw the tetra connector in the 2005 kit of parts from the dimensions given on the FIRST website. I tried everything I know of to get the whole tetra game piece assembly made in Inventor, but I found this very hard to do. I also found the tetra connector very hard to make
If anyone has a whole tetra assembly made from inventor or one that can be imported to Inventor that would be great!
Sheet metal parts, angles, and Inventor are not my thing...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 09-01-2005, 19:42
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Re: Inventor Tetra Connector
Your not alone!!
I have about 3-4 hours trying to model the Clover coupler so I am able to assemble the center goal.
I can model the connector but when trying to assembly the tetra the constraints bomb.
I have tried checking the angle of the three faces and all seems OK (the same). I am not sure if it is an Inventor fold command variance or errors in my sketch that produces angle error when the connector gets folded to the 35.3d angle.
Unread 09-01-2005, 19:52
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
How did you bend the part 33.5 degrees. I thought it might be best to make the triangle in the center and the outer clover parts and mate them together, but there's got to be an easier way.
Ryan
Team 900 (Infinity)
Unread 09-01-2005, 20:00
There is a drawing showing how the geometry is arrainged and on it it says to bend to 35.3d at the start of the radius that is between the Clover Leaves.
I have tried bending it with the bend line at start, middle and end without success.
I'm not sure where to go from here. I'll pobobly wait and talk to the Inventor Guru where I work and see if he has any more success.
Unread 09-01-2005, 20:06
rmmlg's Avatar
#0900 (Infinity)
But where is this bend command to which you are referring.
Ryan
Team 900 (Infinity)
Unread 09-01-2005, 20:08
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Originally Posted by Curt Henderson
Your not alone!!
I can't say that I have a solution (yet) but I am sure the 35.3 degree angle is rounded off. I'll be continuing to work on it ... until I have a solution or someone beats me to it ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 09-01-2005, 20:17
The Fold command is in the sheet metal environment.
I start the part as a sheetmetal part, created the clover leaf pattern and then created a bend lind as mentioned on the print.
When you use the Fold command you have options as to where the bend line will be oriented. I had the best success with having it at the start of the bend.
Good Luck
Unread 09-01-2005, 21:13
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
I've attached our TH Connector Inventor part. I had to move the End of Part marker in the browser to get the file size below 100K. When you open the file, drag the End of Part marker to the bottom of the browser and save the file.
It took a little thought to lay out, but if you do it the way Inventor wants you to, it isn't all that hard - just a little time consuming. The way I made it I was able to fully constrain the tetrahedrons to the connector using Insert constraints for all but the very last mate, which I used a Mate of the hole centers for.
To make the connector "clover" I followed this procedure:
Use the Sheetmetal template and set the thickness to .098 (in Parameters).
Start by drawing the 2.55 and 1.25 layout circle constructions. I recommend using the Fix constraint to nail down the origin of these circles at the origin of the sketch axes.
Then draw construction lines at 30, 90 and 150 degrees, intersecting the origin.
Draw the top "petal" 1.95 circle at the intersection of the 2.55 circle and the vertical axis.
Next, draw a 0.093 circle at the intersection of the 30 degree line and the 1.25 circle. Repeat on the other side at the 150 degree line.
Draw a line tangent to the 1.95 petal and the 0.093 circle.
Repeat these steps for the other three petals.
Trim the "extra" from the 1.95 and 0.093 circles.
You should now have the outline of the part.
Draw the 0.375 hole circles.
Exit the sketch and save your work.
Use the Face feature to "extrude" the sheetmetal thickness. If this fails, go back in the sketch and make sure you can close the loop.
Create a new sketch on the face of the part and draw the fold line as shown in the PDF.
Exit the sketch and use the Fold feature tool to make your bend.
The 35.3 degree dimension on the PDF is rounded from the delta/2 (=arccos(1/3)/2) If you want your connector to mate to the tetrahedron ends, use 35.26438968 (or enter the formula in Parameters, like I did) - otherwise you'll get constraint errors.
By the way, check out Math Forum's Tetrahedron info for the formulas for this beast.
Pete Kieselbach
Unread 10-01-2005, 14:13
AKA: Bradley Rigdon
Thanks!!!!
The file works great.
I have included a picture of the tetra using your piece.
Name:	Game piece tetra.JPG
Unread 10-01-2005, 14:29
Lucid Lucid is offline
AKA: Dan
#1418 (Vae Victus)
Lucid is on a distinguished road
Send a message via AIM to Lucid
It seems that you are all bending it on one line. In reality the clovers have a smooth curve. Have you thought about drawing the curve as a surface inb AutoCAD and importing it? This might be more than you want though.
Lucid
Unread 10-01-2005, 14:40
AKA: Bradley Rigdon
Lucid
It does not matter how they look, just as long as they allow Inventor to make constraints that do not crash!
Unread 10-01-2005, 15:02
SteveC116's Avatar
SteveC116 SteveC116 is offline
SteveC116 has a spectacular aura aboutSteveC116 has a spectacular aura about
I'm not sure what you're making these models for, perhaps the animation? Anyways, if they are supposed to look like the tetras that will be on the field, there will be end caps on the pipe that the connectors connect to (team222badbrad - you just connected the connector directly to a pipe)
Also, I met with Dave Lavery just the other day to discuss what materials and coloring will be on the field, and he told me the pipes for the tetras will be aluminum with a matte finish, while the end pieces will be a similar shade metal, but more glossy.
*Guarana Induced Happiness*
Steve Cohen
Team 116 Animation Captain
http://stevecohen.blogspot.com
Unread 10-01-2005, 15:55
AKA: Bradley Rigdon
Yes I know they need end caps, but I do not have dimensions for those...
If anyone has those would you please share?
I am personally not modeling them for anything in particular. I may eventually build a whole field just for something to do.
I just build the model shown in this thread to see if the tetra pieces part on here, actually allowed me to make constraints in Inventor.
Unread 11-01-2005, 13:55
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Could anyone post a full model of a tetra? I'm not the best with inventor, but I want one that I can look at and spin around and such with.
Jeff Waegelin
Unread 11-01-2005, 17:04
AstroMD AstroMD is offline
AstroMD is an unknown quantity at this point
Question Re: Inventor Tetra Connector
If you do post a file can you also post a .STP (STEP) file so that I can import it into SolidWorks.
Can someone post this on FIRST q/a Joe Ross Electrical 23 16-02-2004 17:28
power connector for 2004 EDU controller kc8nod Robotics Education and Curriculum 6 25-11-2003 16:59
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
90 degree robot modem connector archiver 2001 10 24-06-2002 00:03
DB15, Male 15 pin connector. AdamT Technical Discussion 8 06-02-2002 17:17
