Go to Post Maybe its time we should all get back to the basics...the joy of building something amazing with the people you care about. - Andy Grady [more]
Unread 09-01-2005, 13:18
Billfred's Avatar
Billfred Billfred is offline
Re: One thing to note on the hanging tetras...
When all else fails, check the manual.
If you put a vision tetra on a goal, it counts as a normal tetra--three points. (And then there's the whole bonus tetra thing--check the manual for that.)
If you knock off a hanging tetra, you get nothing for that--but dropping the tetra into the area under the goal is one point.
Unread 09-01-2005, 13:20
copertop's Avatar
copertop copertop is offline
Team President
AKA: JD
FRC #0578 (Blue Lightning)
copertop is an unknown quantity at this point
Send a message via AIM to copertop
The Hanging tetras are worth one point if they just fall and land inside the bottom of the support struts. If you cap with tetra it is worth 3 points and can be used in a tic tac toe if it is the top most tetra. I think that everyone should go for knowcking down the tatras seeing as all you have to do is smack and walk away!
-J of D
Unread 09-01-2005, 18:47
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Just remember that tetras inside (on the floor) goals only count for 1pt if they're there at the end of the match.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 09-01-2005, 18:53
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Yea, the only thing the hanging tetras are good for is to get an extra tetra during autonomous, because after autonomous they go away.
It's not clear in the diagram (or it wasn't for me anyway), but capping the vision tetra puts bonus tetras on your OPPONENTS goals, not on the ones close to you. This makes them better.
Unread 09-01-2005, 19:01
Ferrer's Avatar
Ferrer Ferrer is offline
The Cuban
FRC #0025 (Raider Robotix)
Ferrer will become famous soon enough
Send a message via AIM to Ferrer
I'm pretty sure the bonus is for your OWN corner goals, because I would not see any strategical advantage in letting your opponent start off with anywhere from 6-9 points over you.
And i'm sorry if i get off topic slightly, but, - if you put BOTH vision tetras on any of the center goals during autonomous, would you get TWO extra tetras on the corners? or still only one?
Unread 09-01-2005, 19:06
shotgunking777 shotgunking777 is offline
jthm
AKA: COLESLAW
#0358 (EAGLES)
shotgunking777 is infamous around these parts
Send a message via AIM to shotgunking777
Originally Posted by Billfred
I was looking at the field today, especially at the hanging tetras.
I'll tell you now, if you didn't figure it out already (and by looking at the topics thus far, it doesn't look like anyone has)...
  • Putting a tetra on top will make it drop.
  • Giving it any reasonable amount of force on the side will make it drop.
  • A good whack to the goal about midways (like me hitting it with the palm of my hand with a bit of a grunt) will make it drop. (Note that you don't want to break the field, lest the thing that drops becomes your ranking.)
And one other thing about the tetras that may or may not be addressed soon...holding some of them, a loose nut in one piece of the pipe will cause that part to spin around. Know that if you're planning on building a one-pole grabber.
yeahh well u would need a lot of tork and you would need somthing like a claw machine. but a lot more force.
humankind cannot gain anything without first giving somthing to return. to obtain, somthing of equal value must be lost. that is the alchemy's first law of equivalent exchange. in those days, we really bleieved that to be the world's one, and only, truth.
"There's a saying, 'Every man is put on Earth condemned to die, time and method of execution unknown.' Perhaps this is as it should be. Case in point: Walter Bedeker, lately deceased, a little man with such a yen to live. Beaten by the Devil, by his own boredom, and by the scheme of things in this, the Twilight Zone."
D-Day: look the war is over Wormer dropped the bomb.
Bluto: What? Over? did you say over hey nothing is over until we say it is was it over when the german's bombed pearl harbor: Hell no.
Otter: germans?
Boone: forget it he's rolling.
Unread 09-01-2005, 19:10
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
It looks like if there are two of your vision tetras on the center goal, you get four bonus tetras placed, 2 on each of your corners.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 09-01-2005, 19:15
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
here are some things that i have learned from the rules and might have been said here already.
1. knocking off a hanging tetra is one point if it stays int he goal the whole match.
2. capping a vision tetra put the bonus tetras on your side not the other and if you cap both vision tetras u get 4 bonus tetras on you side.
3. I thought the tetras that you score on are made of pipe not plastic pipe, even so the magnet is weak just smacking it with a little bit of force makes it drop very easily and hitting the sides also makes it drop no matter what the material is pipe or plastic.
at our meeting we were playing with tetras that one of our adult mentors put together with the magnet on it and it was able to fall easily.
If i am wrong on something some one please let me know so i wont sound stupid in another post
Good luck to everyone.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 09-01-2005, 19:58
Addict
Kyle,
You get one bonus tetra for each vision tetra placed on the outside middle goals. You get two bonus tetras for each vision tetra placed on the center middle goal.
This is all per rule 4.3.3, G10, and the accompanying diagram in the rulebook.
Mark Pettit
Unread 09-01-2005, 20:02
Kyle's Avatar
AKA: Kyle Rice
FRC #0365 (MOE)
Originally Posted by Mark Pettit
Kyle,
yea thats what i ment, really its true, but i didnt say it the right way but thank you.
Facebook
Unread 09-01-2005, 20:23
supersy77's Avatar
supersy77 supersy77 is offline
AKA: Steve
FRC #0033 (Killer Bees)
supersy77 is on a distinguished road
Send a message via AIM to supersy77
Question Re: One thing to note on the hanging tetras...
I have a question about these hanging tetras. Are they any differnt then the normal field tetras. I mean do they have metal in them so they can hang and the other ones dont. Or do they all have metal in them so they can hang.
Steve
Unread 09-01-2005, 20:26
Kyle's Avatar
AKA: Kyle Rice
FRC #0365 (MOE)
the connectors on the tops of them all have metal on them so they can be hung, at least there is nothing in the book that says other wise. the only differences that are in the feild tetras and that is the vision and regular ones. the vision ones are 12.5 lbs and the regular are 8.5 also the vision ones have the green on them for the sensors
Facebook
Unread 09-01-2005, 20:30
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
This will need to be adressed in a Q&A because the illustration shows them going to the opposite alliance, but they would be of your color, just on their goals, and this would give you an advantage.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 09-01-2005, 22:24
The prints for the tetras show that the hanging ones have an extra bolt and several wide washers at the top for the magnet to capture.
Unread 09-01-2005, 22:50
That's correct. The figure on Page 8 of section 4 (the game) contradicts Rule <G10> right above it.
My guess is that they transposed red and blue in the description of the figure. Edit: See here for the unofficial answer. http://www.chiefdelphi.com/forums/sh...1&postcount=10
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
hanging Gamer930 Rules/Strategy 7 17-01-2004 18:30
1999....look there for hanging ggoldman Technical Discussion 3 14-01-2004 12:50
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
