Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Unread 09-01-2005, 20:23
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Re: Tetrahedron Connectors
Originally Posted by HPA_Robotics_13
My team has a Flashcut CNC mill. Is this compatible in anyway with MasterCAM or are they different companies so we wouldn't be able to use your file?
I am not sure if it will work with your machine, but you need to have MasterCAM or a program that can convert MasterCAM files to be able to load it to your machine.
You can download the file off the CD white papers here
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 09-01-2005, 20:43
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
We just made the Tetra connectors from 1/8" HDPE sheet we had leftover from the top of the ramp of Stack Attack. Took one from the kit, traced it and cut it out using a band saw and some tin snips. They work great.
(I believe that the connectors you can get from Innovation First are metal for use with the goal tetrahedrons.)
-Mr. Van
Coach, 599
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
shaft connectors gail OCCRA 1 25-10-2003 16:07
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
