Go to Post Smokey the Fisher Price motor says only YOU can prevent rule infractions. - artdutra04 [more]
Unread 09-01-2005, 18:13
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Arm Designs
I know there is a very similar thread already out there, I just wanted to get some input specifically related to the arm design. What kind of design would work better, fork lift or a bending arm? Ideas? Post away.
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 09-01-2005, 18:31
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Arm Designs
I'm not sure how well a forklift would work given that the maximum height of the robot is 60" and the goals with a couple tetras on them would be too high.
Unread 09-01-2005, 18:37
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Arm Designs
If you've ever watched forklifts before, you notice that on some, they dont extend upwards to just the top of the vertical segment. It's like a telescoping pole. the segments in front of the first vertical piece start extending from the top of that point (for our purposes 5') and allow you to reach a much higher height
2001-2004: Team 100
2006-Present: Team 254
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Arm Designs
One thing about being a 14 year team is you get to see alot of previous design that could work with this year's game and I think we found a good one today.
Unread 09-01-2005, 18:39
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Arm Designs
I'm a fork truck driver (narrow aisle) and the front end of the truck is heavy and needs to be counter balanced or it'll tip over. I would assume the same would apply to the robot if something similar was made (I think the robot would end up way overweight and also easy to tip over).
Unread 09-01-2005, 18:48
Re: Arm Designs
But our forklift doesn't need to be on the front of the robot. It could be right in the middle: simply drive underneath the large tetra and deposit your small tetra. That's the advantage of just having tetra frames. You can be inside the big tetra while you cap the little one.
This however, only removes the need for a counterweight, and if I hit you with your center of gravity really high you're going to go a-tumbling.
Unread 09-01-2005, 20:34
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Arm Designs
Forklifting can be worked nicely as can an articulating or telescoping arm. But why would some one on 177 mention that?
The history section of our website should inspire some of you.
http://www.swindsor.k12.ct.us/Highsc...s/clubs/first/
Pete
Unread 09-01-2005, 20:37
Re: Arm Designs
Pete
Because I'm a rookie and don't remember last year
Unread 09-01-2005, 21:02
looneylin's Avatar
looneylin looneylin is offline
I'm rad. U're rad. Let's hug!
AKA: Alicia Lin
FRC #0433 (Firebirds)
Team Role: Webmaster
looneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant future
Send a message via AIM to looneylin Send a message via MSN to looneylin
Talking Re: Arm Designs
I think using the arm is better since you can grab the tetras anywhere around the robot; whereas, the forklift requires you to be in a specific position to grab them. However, with an arm, it's harder to control your robots balance n might tip over, but you may be able to use your arm to pick yourself up.
Tycho Brahe's the man. lol
Unread 09-01-2005, 21:05
Scout-Master
AKA: Chris
Team Role: Scout
Re: Arm Designs
What specific arm designs would probibly work best for manipulating the Tetras?
Unread 09-01-2005, 21:11
BaysianLogik's Avatar
BaysianLogik BaysianLogik is offline
Mentor Emeritus
AKA: Matthew Bays
FRC #1523 (M.A.R.S.)
BaysianLogik is on a distinguished road
Send a message via AIM to BaysianLogik
Re: Arm Designs
The teams ive been on have done both an elevator system and a stereotypical arm design. Both have worked to some extent. The standard arm design is easier to design and build, but i feel the elevator design is the easiest for the drivers to handle. The most important factor in the design is ultamately how much thought and detail goes into it.
Mentor Emeritus-Team 1523: Jupiter HS/GE
Former Mentor-Team 639: Ithaca HS/Borg Warner
Alumni-Team 179: Suncoast HS/UTC
Unread 09-01-2005, 21:59
Nick Mac's Avatar
Nick Mac Nick Mac is offline
Alumni
FRC #0088 (TJē)
Nick Mac will become famous soon enough
Send a message via AIM to Nick Mac
Re: Arm Designs
You're right, an elevator design probably would be easier for the drivers to handle. but depending on which way you make the lift mechanism, you might be limited to coming at the tetra in a specific way. Either design you use is goign to require a lot of practice though. Manipulating those tetras will be no piece of cake.
Nick Mac
Unread 09-01-2005, 23:05
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Arm Designs
Something to consider though about going into a goal structure and then pushing the tetra up is that you risk dislodging the already stacked teras (incuring point penalties and losing posession permanently for the goal to the oposing alliance), there could be tetras inside the goal that impede your movement, and you have to be able to get over into the goal structure without tipping (topheaviness could become an issue). Hope that helps you guys fine tune something to meet your objectives.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
occra 23.
AKA: ryo
None #1481
Re: Arm Designs
we've had considerable success with a few kinds of arms but all 'bending arms'? i think you might call them? our best one was this year's occra one. which wouldnt be too useful in this year's first game but it was a nice 4bar crossing linkage thing.
Unread 10-01-2005, 00:34
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
Re: Arm Designs
My first impression is that (sorry Pete) a forklift would work better. Besides being a lot easier for drivers to use, it's easier to get multiple points of contact on the tetra with a forklift than an arm. If you try to grip a tetra with an arm that only makes contact at one point, you need to make sure you have it gripped hard enough to keep it from rotating. But if you make contact at multiple points it's harder for the tetra to move.
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Designs that would never work... Cyberguy34000 Technical Discussion 60 09-01-2007 20:56
Manipulator designs Max Lobovsky Technical Discussion 10 27-01-2005 07:43
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
