Go to Post Drive Trains are overrated - MaGiC_PiKaChU [more]
Unread 09-01-2005, 22:14
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Vision Tetra Alignment Issues
I have been unable to find anything in the rules that states that the vision tetras will be aligned with the feild in a predefined matter, so we can assume that they could be facing any direction, right? If this is the case, does anyone have any ideas how to align a grabbing mechanism that is dependent on being at a certain angle when grabbing? I was thinking of an algorithm that uses the size of the green blob to determine what angle the tet is relative to the camera...
Too bad it couldn't have been nice and simple, with the bottem bar of the triangular face being parallel with the feild.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 09-01-2005, 22:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Vision Tetra Alignment Issues
Simpler solution, dont have it dependant on the orientation.
Unread 09-01-2005, 22:20
phrontist's Avatar
Proto-Engineer
Well, there are various trade offs if you do that. For instance, it seems to me that most gripper designs that allow for any angle of attack also require the arm to lift higher. For this thread, we'll assume that we want to handle this problem in code, as oppose to alteration of gripper design.
Unread 09-01-2005, 22:22
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
All of the illustrations I've seen have depicted the bar closest to your driver station being parallel to the driver station wall. However, I would ask the FIRST Q&A to verify this.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-01-2005, 22:23
phrontist's Avatar
Proto-Engineer
Oh, that would be too bloody fantastic!
How do you do such a Q&A?
Unread 09-01-2005, 22:24
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Well, let us all know when you find out. I'd like to not have to worry about that in code.
FIRST Q&A:
http://www.usfirst.org/robotics/2005/qa.htm
_
Unread 09-01-2005, 22:27
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
You know the tilt angle of the camera and you know the (x, y) coordinates of the centroid of the blob, so you can make a useful estimate of the distance given the proper transformation which, for simple (FIRST robot) purposes, could be as simple as calling the "distance" to the target the difference between some reference point's y-coordinate and the y-coordinate of the centroid while always keeping the x-coordinate of the centroid at the center of the screen by steering the robot. Of course, this is not an accurate measurement in "feet" (nor is it even linear), but you will get a qualitative estimate that can surely suit your purposes.
Unread 10-01-2005, 03:29
RonStoppable102 RonStoppable102 is offline
AKA: Ron
None #1098 (GI's)
RonStoppable102 is an unknown quantity at this point
Send a message via AIM to RonStoppable102
As stated, I do recall seeing them place the vision tetras like that during the kickoff, I would check in the manual, but its 2:24am.... I'm also guessing that it can be set to track different colors (i'm guessing it interprets color as a function of frequency, but I haven't had a chance to mess with it), we have a kid everyone hates that always wears a red hoodie, for example. Any ideas?
Unread 10-01-2005, 20:56
phrontist's Avatar
Proto-Engineer
Yeah, here is an idea. Tranform that guy everyone hates into a functioning member of soceity through peer pressure and FIRST. Hurting people with robots doesn't do much for the image of first, espesically with the crappy media we have in the US...
Tonight 60 minutes investigates the tragic death of Tommy Redhood, who was killed by a group of students in a nationwide robotics gang. This gang is a looming threat, and determined recruiters may bring it to YOUR CHILDS SCHOOL. *dramatic reverb*
Tetra Math ZZII 527 General Forum 34 22-01-2005 14:13
Vision Tetra Alignment accuracy Rickertsen2 Rules/Strategy 10 21-01-2005 09:18
Most Important Game Aspect of '05 Cyberguy34000 Rules/Strategy 43 15-01-2005 17:39
Inventor Tetra Connector team222badbrad Inventor 24 14-01-2005 10:25
Two vision tetra on center goal? Guido470 Rules/Strategy 8 09-01-2005 17:50
