Re: Restricted to the Anderson Connectors in the Kit?
I think some of the rules are restricting teams who know how to to a good quality nice electrical job.
Electrical is often hard for many teams. I've seen robots show up at a regional
with the pump wired straight to the pressure switch. FIRST is trying to eliminate confusion here as well as standardize some robot characteristics. |
As Aidan pointed out above, the Anderson connector was required for 2004. Although I have seen teams burn and melt this connector, they were few and far between. They do require proper care and feeding. Do not use alligator clips to connect the battery charger to them. Buy another connector and add it to the leads on your chargers. (watch for polarity, the connectors are marked.) Keep them clean, dirt and other abrasives can damage as much as gator clips. Check for proper insertion and mating. Bent contacts will not give the low resistance needed for high current applications. And here is the biggy...design your robot for efficient electrical usage. It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change.
May we use the same exact model housing/contact but a different color and our own high quality 6 guage wire?
Here is the way I interpret this rule...
<R48> The ES-18-12 Battery, the Main 120 Amp Circuit Breaker, and the IFI CB/Distribution panel must be connected as shown in the diagram. The ES-18-12 Battery must use the Anderson Connector and the copper SLU-70 lugs provided in the Terminal Supply Bag. The Battery terminals and the SLU-70 lugs must be insulated with shrink tubing and/or electrical tape. You may use additional lengths of #6 red and #6 black wire to reach the panel as needed to make the above connections. The circuit breaker must be readily accessible for inspection and testing at each competition event. The #6 and the red Anderson connector provided must be used. Elsewhere in the rules, wire minimum sizes are specified, but no additional reference is made to #6. Simple answer is use what is provided. The tradeoff for lower resistance/higher weight is not significant to warrant the change. (The wire length should be too short to matter.) I would like to know what "high quality" #6 wire is? |
#7
ID: 1167 Section: 5.3.5 Status: Answered Date Answered: 1/17/2005 Q: In reference to rule R48, can we use wire larger than #6 (such as #4) diameter between the battery and the Anderson connector and between the Anderson and the breaker panel? A: Yes Specifically that I said on the battery side also. On the other hand, the Anderson's are only designed for 6 gauge, not for 4. Tomorrow I'm going to try using some 4 gauge with some extra contacts I have. Edit: Fixed spelling, stupid 8 AM classes. Last edited by BrianBSL : 20-01-2005 at 08:04. |
#8
Interesting answer. Go figure!
#9
highly suprising, tell us soon wut u find so i can go out and buy the cables tonight and use it
hmmms tho just to be clear does it mean we can replace alll 6 awg wires with our own stuff? just the leads to the batteries? or can it be used at the PDB and 120 Breaker and robot battery leads? |
| need standard kit gearbox | Korbin | Kit & Additional Hardware | 0 | 15-11-2004 21:18 |
| PWM Style .100 pitch Male Connectors | BrianBSL | Electrical | 2 | 05-10-2004 19:43 |
| Q&A Discuss: How many Van door motor(s) come with the kit? | CD47-Bot | Extra Discussion | 1 | 08-01-2003 11:07 |
| RJ-45 connectors, DB25 connectors and the like: legal or no? | Andrew Wyatt | Technical Discussion | 6 | 04-01-2002 22:53 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
