Re: Tetra Math
one tetra added to the goal is a height increase of exactly 3.5 inches. Therefore, if you just add about 5 tetra's, thats about another foot and a half. So if you have an arm, you would need to have a 10.5 foot at full extension to out class other arms
Re: Tetra Math
Re: Tetra Math
It is 6 inches per tetra...this is comming from someone who's seen them built and stacked on eachother.
Re: Tetra Math
i calulated using a formula i learned in statistics, the width of the pole vs height/ complicated math suff
Re: Tetra Math
pole=pvc pipe
Re: Tetra Math
i made tetra's too and did see that it was 3.5, ill go see if the tetra's was built properly
#7
Re: Tetra Math
sojouner06, try to edit your posts instead of creating new ones.
ftp://67.170.35.253/robotics/Posting.swf Anyways, did you take into consideration about the end-caps. Also, when looking at the sidelines during the kickoff, it looked more like 6 inches. |
#8
Re: Tetra Math
I thought that the tetras used at the actual competitions don't have PVC endcaps but instead have flat pieces that screw into the PVC?
#9
Re: Tetra Math
i was in manchester and saw the offical ones and adding them ontop of each other adds SIX inches....i also tested the how many fit under a goal and 7 perfectly stacked will make it as long as there are no tetras ontop of the goal. if there is a tetra ontop of the goal then you can only fit 4 under
#10
Re: Tetra Math
Re: Tetra Math
think about it here, 6 inches, thats half a foot. Even with end caps at the largest constraint is 4 inches. It is physicaly impossible for it to be a six inch increase per tetra. IMPoSIBLE!!!!!!!!!!!! unless someone put it on a freaky way
#12
Re: Tetra Math
We've also built tetras...it is 6". The sides of one tetra do not even come close to being flush up against the sides of the one below it. I think it is partially because the sides of the lower one get jammed into the corners of the one on top.
#13
Re: Tetra Math
I wish i had seen this thread sooner. I had to do this math today but oh well i like math. Nice thread.
#14
Re: Tetra Math
ok i believe it is 6 inches, but wait, how thick are your pipes. The manual said they should be 1 and a quarter inches at pipe and 1.(4-9) inches at endcap
or...maybe...how long are the pipes themselves? 40"? 48"? 70"? Last edited by sojouner06 : 12-01-2005 at 22:38. |
#15
Re: Tetra Math
| Electromagnets to pick up tetra? | xxerin | Rules/Strategy | 26 | 10-01-2005 07:30 |
| White Paper Discuss: 296's CORDIC Math Library | CD47-Bot | Extra Discussion | 5 | 28-04-2004 20:01 |
| Math project | edomus | General Forum | 4 | 01-04-2004 13:12 |
| Logical statements or math formulas | Manoel | Programming | 1 | 16-02-2002 23:29 |
