Go to Post FIRST encourages us to innovate and try new things, lets do the same for them. - Katie_UPS [more]
Unread 10-01-2005, 01:20
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Shop tools, any suggestions?
Hi,
I know it's already build season, but now we have the ability to possibly get a grant for some machine tools.
So far, I read some old threads and decided to try and get a Rong-Fu desktop mill/drill machine. For those who have one, how is it? Would you recommend buying it?
Also, we're looking for a metal band saw, preferably vertical. I found a few but I have no idea how good it is. For year's we've been using a wood bandsaw with a metal cutting blade... it isn't pretty.
We have a drill press, it's old but it still works well. Hand tools are not an issue.
Are there any other tools which would be useful for a robotics team? Note, we do have a price limit, not sure what it is, but we can't ask for radical things like a bridgeport CNC.
Thanks in advance,
Jonathan
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 10-01-2005, 01:48
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
Re: Shop tools, any suggestions?
WHS Robotics was at the regional my team attended last year, in Sacramento!
I would suggest getting a miter saw. This is useful for cutting aluminum: such as tubing for a frame.
We love our table saw (although we need a new one) and use it regularly for cutting lexan and polycarbonate as well as aluminum plating. It's also been an integral part of constructing our playing field in the past -- cutting lumber -- but the playing field requires much less carpentry this year (much to our relief).
We also have an oscillating, table beltsander which comes in handy sometimes. It wasn't very expensive at all.
Good luck with your new toys!
Unread 10-01-2005, 02:25
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
briholton is on a distinguished road
Thanks in advance,
Jonathan
Team 752 has a limited budget as well, but we bought a grizzly lathe, bandsaw and milling machine. We got the smaller, cheap versions of all these since not only is our budget limited, but so is our space. I would not want to use these tools every day to make a living, but for our use, they are fine. Last year we didnt have them, and life was very difficult. You might want to consider something to weld with and a press.
"Youth is wasted on the young"...MT
Unread 10-01-2005, 02:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
First I would recommend a horizontal bandsaw. It is very useful for cutting down long lengths of any size material. We use it more than the vertical. We have also found an arbor press (manual, not hyrdraulic) to be very useful. Also, a cold saw like what they use on American Choppers comes in handy sometimes but they are expensive.
Unread 10-01-2005, 03:10
RonStoppable102 RonStoppable102 is offline
AKA: Ron
None #1098 (GI's)
RonStoppable102 is an unknown quantity at this point
Send a message via AIM to RonStoppable102
About the vertical bandsaw, we have one in our shop. From what I've seen, it seems as if it takes alot of skill to get the right cut. It is usyally fine for small cuts on stock material, but whenever I cut somthing over 3" theres always some descrepency, even if I sharpie in a line. Like sanddrag said, I would reccomend a horizontal bandsaw, the one we have is awesome, it takes almost no effort and makes clean cuts. As for other shop tools, we also have a little stationary vertical disc sander/belt sander, that thing is awesome for rounding off sharp things, frehanding curves, ect... Good luck!
Unread 10-01-2005, 10:56
Lucid Lucid is offline
AKA: Dan
#1418 (Vae Victus)
Lucid is on a distinguished road
Send a message via AIM to Lucid
I agree with the table saw and miter saw suggestions. I am our teams shop manager, and we just bought a cheaper mill. Make sure that iff you buy a mill you add in the cost of all the bits/clamps/accesories that wou will need or find out what it comes with them.
Lucid
Unread 11-01-2005, 21:44
DivideByZero DivideByZero is offline
DivideByZero is an unknown quantity at this point
I'm part of a second year team that got by with a drill and a drill press as our only power tools (everything else was hand tools last year, and we still placed 15th out of 75 at our regional). Having some debate on what to get this year. Would a jig/sabre saw be of any use, in order to cut framing and large sheet metal (I'd imagine a miter saw to be too difficult if the metal is more than 2x the cutting range, and space/cost are major concerns).
Unread 11-01-2005, 22:21
csquared05 csquared05 is offline
#1005 (Csquared Robotics)
csquared05 is an unknown quantity at this point
Send a message via AIM to csquared05
a reciprocating saw may be important at regionals if you find your CG too high or functions worthless. Just gut it, we did it last year. It helped our preformance, but it wasn't our finest year
Unread 12-01-2005, 02:01
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I am trying to convince my team that we need to get at least some basic machine tools, and I am specifically interested in something we can use to machine our own parts for transmissions and such. Where could I find information on this topic, and how much money would I be looking at for just a single machine we can at least control from a computer? (as you can tell I havent the faintest clue what I am talking about)
Unread 12-01-2005, 02:06
24 Hours of LeMons?
Russell, it depends on what you want the machine to do. If anything, the most useful (IMO) machine tool you can get other than a drill press and bandsaw probably is a lathe. Now, for a computer controlled one (CNC), depending on the size and quality, you're probably going to spend quite a bit more than a $1000.
Anyways, can anyone recommend a metal band saw? Vertical and/or horizontal.
Unread 12-01-2005, 02:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Some horizontals will actually flip up and act as vertical bandsaws also.
I imagine they cost far more though.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 10:26
Aaron's Avatar
Aaron Aaron is offline
FRC #3719 (Whaler Robotics)
Aaron is on a distinguished road
Send a message via AIM to Aaron
the short and sweet list of most used tools that i have needed over the last four years.
-Drill press
-band saw
-18v cordless drill and reciprocating saw
-lathe
-drill mill
-grinder
-sander
-drill bits
-reamers
-file set
(our last three robots have probably been 95% constructed with these tools)
Team 3719 - 2013-Present
2014 RI District Judges Award
Team 1493 - 2007
2007 UTC Connecticut Regional 2nd Seed and Semi- Finalist
Team 11 - 2001-2005
2005 New Jersey Regional Chairmans Award Winners, Palmetto Autodesk Visualization Award Winners, Palmetto Judges Award Winner
2004 Palmetto Regional winners of DiamlerChrysler Team Spirit Award, Palmetto Regional Winners(281, 11, 122), Curie Division 5th seed (11, 190, 179)
2002 J&J MidAtlantic Regional Finalists, Canadian Regional winners of the Xerox Creativity award
Unread 12-01-2005, 10:43
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
With the addition of your machining capabilities, don't forget to add some precision measurement equipment. We just added a great team sponsor who distributes SHAN tools:
Allen Design LLC PM me if you need vernier calipers, micrometers, or other products - these are great tools at a VERY affordable price!
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 12-01-2005, 14:11
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
we have constructed a beautiful tool cart this year, see it at trenton, ohio, and atlanta. we are in the process of stocking it up with pretty much an entire tool shop in a cart. We are considering buying a mini lathe, drill press, and/or grinder. but the weight limits on shipping my stop us from getting the stuff.
Unread 12-01-2005, 14:56
Twstdkittie's Avatar
Twstdkittie Twstdkittie is offline
You can't kill integrity
AKA: Kittie
#0384
Twstdkittie is on a distinguished road
Send a message via AIM to Twstdkittie
Yeah, we have a gorgeous wood cart. It's awesome. (And there's even room for mini-fridge!!
Rise inside, free your mind
Raise your fist to signify
We stand in defiance of hatred and deception
Shop Safety Training Resources Andrew Schuetze General Forum 4 14-12-2004 13:28
Shipping Tools falconmaster Technical Discussion 9 30-03-2004 08:02
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
How important is a machine shop? archiver 2001 13 24-06-2002 04:14
