Go to Post I'm unconvinced that this thread itself is not a performance art piece. - DCA Fan [more]
Unread 10-01-2005, 02:33
jakk jakk is offline
Jonathan Kobayashi
FRC #0368 (Kika Mana)
jakk has a spectacular aura aboutjakk has a spectacular aura about
Arrow trouble with pwm speed controller
team 368 kika mana
our team is having trouble with the speed controllers for our robot. it seems that the connector won't fit....is anyone else having this problem?
Unread 10-01-2005, 02:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: trouble with pwm speed controller
If you are referring to the PWM connector, it will fit, just tightly. In the past there were problems with them falling out so this is why it is made this way. When you puch it in just make sure that you are not going to bend the pins inside.
Unread 10-01-2005, 02:41
Jonathan Kobayashi
---> ok, thank you very much. i'll go and double check on that
Unread 10-01-2005, 02:48
Electrical Engineer
Rookie Year: 1995
Originally Posted by jakk
team 368 kika mana
Jakk,
There are two types of pwm cables in use today. One style is made by Hitec and JR. The other style is made by Futaba. The Futaba is called a J style because it has a polarizing tab on one side (see http://aircraft-world.com/prod_datas.../all_servo.htm near the bottom of the page).
If you are trying to use the J style, you must cut off the tab for it to fit correctly.
Hope this helps.
Mike Betts
As easy as 355/113...
Unread 10-01-2005, 02:51
Jonathan Kobayashi
---> thank you
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
