Go to Post Is it weird we think speed controllers are sexy? - vivek16 [more]
Unread 10-01-2005, 05:29
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
MPLAB build error
This is pretty sad, I know. But does anyone know what this means? And how to solve it?
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F8520 "asm_lib.asm" /l"asm_lib.lst" /e"asm_lib.err" /o"asm_lib.o" /d_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"c:\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"c:\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
D:\Jan8code\ifi_picdefs.h:1289:Error [1099] *** Error - Invalid 18f8520 header file!
Halting build on first failure as requested.
BUILD FAILED: Mon Jan 10 00:40:29 2005
That's the error I got while trying to build (compile) the DEFAULT code! I did not modify the picdefs header file so I don't know why this error would come up. Did I install the program wrong or something? I also tried compiling the camera code from the innovation first website and it isn't working. Did anyone sucessfully download and use the camera code yet?
Unread 10-01-2005, 07:19
Electrical Engineer
Rookie Year: 1995
Re: MPLAB build error
Interesting... It compiles ifi_startup.c OK. Startup uses the same file... You have something else wrong...Did you change anything at all?
Mike Betts
As easy as 355/113...
Unread 10-01-2005, 09:52
We this error turned up on the forums during the season last year, but it reportedly "went away." You can seach on "banked" to easily locate that conversation.
What seems to be happening is the #define __ifi_picdefs_h_ is lost by the second time ifi_picdefs.h is included.
or
You've added a #define of your own for BANKED.
Unread 10-01-2005, 10:42
BrianJennings BrianJennings is offline
Sleep is optional
None #1519 (Mechanical Mayhem)
BrianJennings is an unknown quantity at this point
Send a message via AIM to BrianJennings
Do you have the C182.4 compiler? It might be trying to get a Lib or Include that it doesn't have. Just a thought....
"it's googleable " -- the_undefined
Unread 10-01-2005, 14:01
#0368 (Kika Mana)
I haven't changed anything to the default code. I'll try downloading the default code again to see if I accidentally modified it. I also want to try uninstalling the programs and reinstalling them later on today. Here's the steps that I followed:
1) Install MPLAB IDE v7.00
2) Install C18 v2.4 compiler
3) Install IFI Loader (newest one from innovation first)
Are these the steps that you guys followed?
Also, just a question, what does this do exactly.. #define __ifi_picdefs_h_?
I see the #define _"filename"_ command at the top of every header file.
Unread 10-01-2005, 14:10
The installation order is the same I followed.
The sequence:
#ifndef __ifi_picdefs_h_
is to prevent the include file from being loaded twice by the file that's being compiled. The first time the file is loaded that #define doesn't exist, so if the compiler sees that file loaded a second time (when the #define has now been declared) it knows to skip over the whole include because it's already been done. This is typically a potential issue when you use nested includes.
You're getting your problem when ifi_utilities.c pulls in ifi_default.h (via the include statement) which in turn includes ifi_picdefs.h
This shouldn't be a problem, but what seems to be happening is that something is remembering the define BANKED (used only within ifi_picdefs.h) from the previous compile of ifi_startup.c
Unread 10-01-2005, 14:14
Sleep is optional
That is the steps that I followed. Do you have the C18 2.4 compiler? If so, PM me please... thx
Unread 12-01-2005, 13:36
#0368 (Kika Mana)
Have you downloaded the new compiler yet? If not, it's posted on the FIRST site, and the link works!
Also, I finally got the code compiled by uninstalling the programs and just installing the ones included on the CD (rather than the upated ones).
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
MPlab error ryan_f Programming 9 24-05-2004 07:30
Error message in MPLAB IDE dddriveman Programming 11 18-03-2004 06:34
Mplab startup error Team 869 Programming 6 25-01-2004 10:41
