Go to Post Changing the world starts with changing yourself. - Jeremy_Mc [more]
Unread 08-01-2005, 16:20
Gal Longin's Avatar
Gal Longin Gal Longin is offline
Gal L.
#1578 (IsraBot)
Gal Longin is an unknown quantity at this point
Send a message via ICQ to Gal Longin Send a message via AIM to Gal Longin Send a message via MSN to Gal Longin Send a message via Yahoo to Gal Longin
2005 electrical diagram
where can I find the 2005 electrical diagram? did they release it yet?
"Only two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -Albert Einstein.
2005 Israel regional Finalist
2005 Israel regional Johnson & Johnson Sportmanship Award
2005 Israel regional Website Award
Unread 08-01-2005, 16:22
Noah Melamed's Avatar
Noah Melamed Noah Melamed is offline
FRC #0637 (Mr. T)
FTC #0030 (Mr. T)
Noah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura about
Send a message via AIM to Noah Melamed
Re: 2005 electrical diagram
I cant find it either and ive been looking for 20 minutes now :-(
Unread 08-01-2005, 18:33
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Its basically the same as last year (keep in mind I'm of mechanical origin, so I may be wrong). This is my 4th year doing this and from what I've read the only major changes are the new camera sensor bundle with its own servo outputs for tilt/pan and the like, and a new "smart" breaker panel. there is a spot on the robot interface for the camera sensors it looks like, there is a new set of 4 pins labeled as the ttl serial port to use with an adapter to connect he calera, and the smart breaker panel connects via db9 serial cable into the programing port of the RI to feed data back to the dashboard about which breakers are tripping, or have tripped. I'm not sure of any other changes, but I don't think there are many besides the ones above. Check out IFI's website, they have a pretty nice overview of this years electrical system.
http://www.ifirobotics.com/frc-robot...overview.shtml
Good Luck Teams!
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 08-01-2005, 18:55
There is no 40 amp breaker panel. All breakers are planned into the new IFI breaker panel. From first look, IFI has another winning design. The only downside if this is the only distro that can be used, there can be no split breaker panels. (i.e. one for each side of the robot.)
Unread 08-01-2005, 18:57
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
All the fuses (20amp, 30amp, and 40amp) plug into this new breaker panel.
Please correct if I am wrong.
Matthew
Unread 08-01-2005, 20:33
jparkteach's Avatar
jparkteach jparkteach is offline
FRC #2070 (Ridgefield Robotics)
jparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to behold
Send a message via AIM to jparkteach
It's also a "SMART" panel that can send information to the controller, thus ultimately to the operator interface and even the dashboard! You'll have to connect a serial cable into the program slot. The only downside is that we'll have to remove it every time we need to download the program into the controller...
Unread 08-01-2005, 20:46
coreyjon's Avatar
Flight Engineer
Matt, from the pictures I have seen, you are right, the 40 amp breakers are on the very top. I see what Al is saying though, in the past we have had our 40 amp breaker panal and are other breaker panal in differant locations. This year however it looks like we will be dealing with one central MDP. I like the new design, and I don't forsee many problems due to the consolidation of the two panals in to one. I like the added features such as a data relay to the operator interface that allows for program critiques and design cretiques. You'll know which breaker is tripping and when, which I can see as being a good thing to know, while we have done fine without it in the past, I think it will make it easier for certain troubleshooting events. I like the idea of a status led as well, and I'm looking foward to testing out the new hardware.
Unread 09-01-2005, 00:13
AnkurG's Avatar
AnkurG AnkurG is offline
Vice President
None #1072 (Harker Robotics)
AnkurG is an unknown quantity at this point
Send a message via AIM to AnkurG
So I am guessing that nobody knows where the power distribution diagram is? Reason is because it helps a lot for rookies even if there very slight changes from last year's diagram.
Blood, Sweat, and WD40
Unread 09-01-2005, 08:47
coreyjon's Avatar
Flight Engineer
Rookie teams, or teams that want to brush up on the electrical side of things should check out this:
http://www2.usfirst.org/2005comp/Man...idelines_C.pdf
starting on the bottom of page 13. There is also some rules in section 5 of the manual pertaining to the electrical system.
http://www2.usfirst.org/2005comp/Sec...-The_Robot.pdf
The rules start on page 19. I have a feeling that I am missing a bigger electrical section somewhere, In past years the section was large, and full of large diagrams, and I really haven't seen that yet this year, but I'm sure they are to come, or may already be tucked away in the manual for us to discover.
Unread 10-01-2005, 07:04
Be patient, nobody is wiring their competition robot this week. I am sure FIRST is just putting the finishing touches on it and will release it soon, perhpas as a team update. Stayed tuned...
Unread 10-01-2005, 07:25
Electrical Engineer
Rookie Year: 1995
Be patient, nobody is wiring their competition robot this week...
Not true Al... Our mechanical group has committed to having the base built by Saturday and I have already commited to my controls team to have our competition base wired this weekend.
Mike Betts
As easy as 355/113...
Unread 10-01-2005, 08:30
Mike,
Your final Final?
Unread 10-01-2005, 08:53
Electrical Engineer
Rookie Year: 1995
Mike,
Your final Final?
Until we change our collective minds (or break it)...
Mike Betts
Unread 10-01-2005, 09:00
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
lol then you/your team has been around for a few years and between the image here and other robots you probably having sitting somewhere you can access fairly quickly.....you all should be able to put this thing together without THE SCHEMATIC
gl
Unread 10-01-2005, 09:01
As in "I am schizophrenic! And so am I!"
Electrical Schematic/ Wiring diagram sanddrag Electrical 9 11-01-2005 12:51
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman FIRST E-Mail Blast Archive 0 05-01-2005 16:46
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
