Go to Post If my shop was snowed in and my unfinished robot was sitting in there, I'd dig it out with a plastic spoon or melt it out with a Bic lighter if I had to. Every hour counts. If there's a will, there's a way to make it happen. - sanddrag [more]
Unread 10-01-2005, 07:45
SirLancelot SirLancelot is offline
AKA: Anna
FRC #1502 (Technical Diffaculties)
SirLancelot is on a distinguished road
2D Extrusions on AutoCAD
How does one extrude 2D figures on AutoCAD? I'm very new at this.
Unread 10-01-2005, 07:56
Electrical Engineer
Rookie Year: 1995
Re: 2D Extrusions on AutoCAD
Click modify->solids editing->extrude faces (in ACAD 2000). The only tricky part is that the surface is defined by an unbroken polyline. Refer to the Help button in ACAD to learn more about this...
Mike Betts
As easy as 355/113...
Unread 10-01-2005, 08:11
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
PEDIT-
follow instructions
you want to JOIN-
then when you have a complete 2d Figure
EXTRUDE-
Select the object
and say how much you want to extrude it. Say 10"
Unread 10-01-2005, 09:02
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
First, you must have a region to extrude. The region command can be used to create the region(s) that you wish to extrude. To region lines/plines/splines, there must be an unbroken perimeter to use as the base for the region.
Once the object is regioned, then you extrude using the command of the same name, and follow the instructions in the command line:
select the object(s) to be extruded, hit enter
type in the height of extrusion, in the base units of the drawing, hit enter, or goto <path>
put in the taper angle that you wish to be used in the extrusion, hit enter
<path> to select the path option, you must first have a line or pline to extrude along, and then do the extrude command. Select the object to extrude, enter, p(ath), enter, click on the path, enter
Hope this helps!
Squirrel
If it doesn't, then pm me or email me at squirrel.rock@gmail.com.
However, I check my pms more often than my email, because I cannot access my gmail at school, but I'm typing this while at school .
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 10-01-2005, 11:10
Lucid Lucid is offline
AKA: Dan
#1418 (Vae Victus)
Lucid is on a distinguished road
Send a message via AIM to Lucid
The path option is a great feature of autocad. You can do ment tubes or wire type things by drawing out a spline as a path. Also, Make sure that when you extrude that the UCS XY plane is parrallel to the closed poly that you are extruding
Inventor to AutoCAD rmmlg Inventor 10 14-12-2004 21:26
Autocad error?!?! Adam Y. Inventor 9 18-11-2004 11:04
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
AutoCAD Viewer Gadget470 OCCRA 2 25-09-2002 03:19
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
