Go to Post This is what I love about FIRST everyone helps and asks why later. - Kyle [more]
View Poll Results: What's most important in this year's game?
Strength/Power 11 16.67%
Speed/Maneuverability 25 37.88%
A happy medium of both 30 45.45%
Voters: 66. You may not vote on this poll
Unread 10-01-2005, 06:26
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Re: 2005 Drivetrains
It is important to be able to control your speed to help maneuverability, however you do need some pushing power. One of the biggest things is for the drivers to be able to control the robot well.
Unread 10-01-2005, 08:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by Greg Needel
this is not possible because you wont have the traction to transfer that force to the floor.... kinetic force = (coefficient of friction)*(the normal force)
since the coefficient of friction can;t be more then 1 and your normal force is essentially the weight of your robot (force that acts perpendicular to the surface)
therefore your max force can not reach 340 ft-lbs
i would recommend recalculating your theoretical force to a more reasonable value around the max weight of your robot but even that will be overkill and you will just end up spinning your tires
Greg, you're right about the wheel slip being the limiting factor, but with interlocking surfaces or certain combinations of materials, μ can exceed 1; it's a convenient approximate upper bound, but it isn't a physical limit. (See here.) Some FIRST teams have empirically determined the coefficient of friction of rubber tread on carpet to be around 1.2; it all depends on your particular wheels.
Unread 10-01-2005, 08:21
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Additionally, that is probably the torque at stall. You should not be able to stall your motors (or even get close) in low gear.
Team 1257
Unread 10-01-2005, 08:59
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Just a thought perhaps the only factors aren't speed and torque, but say... manueverability? I think the 'strategy on the fly' aspect of the game will reqire a large amount of agility(not the same as speed) and reliability from the robots to be able to adapt with the strategy.
Going pusher won't guarantee that you'll hold an area against a fast bot, and being fast won't mean that you'll outfox the pusher bots. Having a transmission doesn't guarantee the best of both worlds. The great thing about this years game I think is that with three-team alliances and 9 goals strategy becomes a lot more dynamic. Pushers and nimble bots both seem to have their place and use this year.
Just make sure that your particular strategy does not require more speed or torque than your bot can handle.
(btw i'd like to point out that speed and manueverability are not the same)
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 10-01-2005, 09:08
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Originally Posted by Xufer
i think its going to be hard to get all three robots behind that line it looks like such a small area.
Go look at a scaled drawing of the field, and put 28" by 38" into that scale, and then compare the size of the robot to the space between the "endzone" goals.
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 10-01-2005, 10:04
REVving up for a new season
FRC #2848 (All-sparks)
wow....i guess this just goes along with the saying "you never stop learning" all of my professors always just told us 1 was the max and while you can get a coefficient higher then 1 it still wouldn;t constitute a drive train with theoretical torque of 320 ft-lbs... thanks Tristan for the education
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman FIRST E-Mail Blast Archive 0 05-01-2005 16:46
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
