Go to Post Here's some food for thought: Does your FRC program need the students, or do the students need your FRC program? - sanddrag [more]
View Poll Results: Which setting do you use for the Victors on your drive train?
Coast 7 50.00%
Brake 5 35.71%
We have a switch to control it 0 0%
What? 2 14.29%
Voters: 14. You may not vote on this poll
Unread 09-01-2005, 03:24
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
victor brake/coast setting
According to the manual, the jumper to set brake/coast on the Victor can be replaced with a limit switch - not particularly useful. According to the custom ciruits rules, we can't make something to replace the jumper. I'm also assuming that a relay or transistor would fall under the category of custom circuit. I just wanted to make sure that I'm interpreting the rules correctly. It just doesn't seem like that great of an idea to actuate a limit switch with a servo or soleniod or something to dynamically change the setting.
Unread 09-01-2005, 08:43
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: victor brake/coast setting
Last year there was a thread about this. The way to do it completely within the rules, is to use a servo to act on the "limit switch." This year there is no rule limit on how many servos you use on your bot, there will be a point where you run out of places to plug them in.
Unread 09-01-2005, 12:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm not certain of any of the rules and I don't make any claims on the legality of this but look at it this way, what is a jumper? What is it's purpose? It bridges the gap between two pins. A physical electrical conection. What if instead of that little bar of metal, you had a wire connecting those two pins? What if this wire became an inch long? Then why not a foot long? And what if cut this wire right in the middle and install a switch. Opening and closing this switch would have the same effect as placing and removing the jumper.
Unread 09-01-2005, 14:10
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Well, my goal was to use a relay or something so that it can be controlled in software. Useing a servo to actuate a switch doesn't seem very efficient - or fast - to me.
Unread 09-01-2005, 14:12
You might surprise yourself. Use a switch that is easy to "open" and "close" like a limit switch with one of those long metal strips.
Unread 09-01-2005, 14:28
Umm Errr...
We have done this with an array of relays for the last two years and had no problems with inspection. I havn't read the rules carefully enough to see if it is legal this year though.
------------------- Edit --------------------------
It Looks to me like Rule R51 prohibits this sort of thing. There may be a loophole however. I believe that all the jumper does is pull a pin either high or low. there is no rule that i can see that prevents you from directly connecting this pin to a digital output. I wouldn't consider this a "custom circuit". This may be a loophole but i feel it does not go against the spirit of any rules. You are not providing a PWM outpur, not directly controlling movement and not posing a safety rist. BTW I believe the signal pin is the middle one.
1139 Alumni
Unread 09-01-2005, 15:52
AKA: Tom Cooper
This method (direct connection to the controller) was addressed last year in Q and A on the first site, and as I recall was not allowed, The relay method would seem logical even if you have to drive it with a spike. I would suggest spell out exactly how, including a wiring example and submit it to the Q and A process.
Thanks in advance -Biff
Unread 10-01-2005, 08:37
Sci,
Please keep in mind that many rules are made to prevent damage to IFI hardware or to prevent bodily harm. (It's expensive to replace.) Using a limit switch prevents any team from connecting power supply to one of the pins. It is also to prevent a team from using underrated electrical components from supplying power to the motors. A fire on the field could rain on everyone's parade.
Unread 10-01-2005, 08:47
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
If anyone posts a Q&A on this, please post it here. It doesn't seem like there should be anything wrong with driving it with a digital output.
Team 1257
Unread 10-01-2005, 08:59
Electrical Engineer
Rookie Year: 1995
Max,
The digital outputs are powered from the controller. The brake/coast jumper is powered from the Victor. Directly connecting two power sources is what they are trying to avoid here. A dry contact switch is what is required to replace the brake/coast jumper.
Mike Betts
As easy as 355/113...
Don't make these kind of assumptions. A closing (dry, no voltage) contact is what is required.
Unread 18-01-2005, 00:37
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Q&A says that the relay is fine as long as it's allowed by the part use flow chart. Pretty much, if you can get a relay from the approved vendors, it'll be fine.
question #1189
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 20-01-2005, 14:39
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Victor Braking
I know that the vics can go into break mode when the jumper is in one position, anyone know which that is (left or right). The help file doesn't show it. Thanks!
Unread 20-01-2005, 14:52
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Vic Breaking
If I remember right, when the jumper is in position A-B, the Victor is in brake (not break) mode. When it is position B-C, the Victor is in coast mode. I also searched and found it in an old thread. I'm assuming things haven't changed since then...
It should be pretty obvious if you have it in the wrong position when you test it out.
Unread 20-01-2005, 14:53
REVving up for a new season
FRC #2848 (All-sparks)
Re: Vic Breaking
from the ifi manual
Brake / Coast Configuration
The Brake / Coast jumper is used to set the speed
controller’s action during a neutral condition. The Brake
provides significant resistance to motor rotation and is
recommended for motors driving linkages and arms that
can be back-driven by gravity or other external forces.
The speed controller checks the status of the jumper
approximately 60 times per second. This allows the user
to change from brake to coast during operation. A limit
switch may be connected to the jumper connector instead
of the jumper. The limit switch can be triggered by
various means including the use of a servo.
Brake / Coast Guidelines:
1. The jumper should always be installed in either the
Coast or Brake position. If you lose the jumper, a
standard computer jumper will work.
2. If no jumper is installed, the speed controller will
default to a Brake condition.
3. The Coast condition sets the output to an open
circuit during neutral.
4. The Brake condition sets the output to a short across
the motor leads during neutral.
if the pin is set to the left it is set to break
if the pin is set to the right it is set to coast
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
setting autonomous mode Allison Programming 10 08-03-2004 20:37
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Need help setting up phpBB on a coolfreepages.com website LBK Rules Website Design/Showcase 5 30-03-2003 20:02
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
Jealousy is setting in now!!!! archiver 2000 5 23-06-2002 23:46
