Go to Post If FIRST isn't your life, then you're doing something wrong! - BandChick [more]
Unread 10-01-2005, 13:53
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
2004 vs. 2005 controllers
The 2004 and 2005 controllers are exactly the same, right? Meaning that we can throw code onto whichever of the two we want and it will work? It appears so, but I'd like to check before I frag my controller in exciting fashion.
Unread 10-01-2005, 14:14
Re: 2004 vs. 2005 controllers
They're not identical. I noticed two differences immediately: the power connections are now blade connectors, and there is a new three-pin header for extending the Prog and Reset buttons.
According to the documentation, you can use a 2004 RC on a 2005 robot, but you must load updated firmware first. It looks like you can not use a 2004 OI, however. (I suspect the communication protocol has changed between last year and this year.)
Unread 10-01-2005, 14:27
FRC #1747
What documentation are you looking at? Most of the stuff on InnovationFirst seems to be 2004 controller stuff. And, according to this,
The new FRC Robot Controller is not compatible with pre-2004 Operator Interfaces. The Operator Interfaces is also not compatible with pre-2004 Robot Controllers
Thanks.
Unread 10-01-2005, 14:59
Billfred's Avatar
Billfred Billfred is offline
The 2005 manual.
Originally Posted by The 2005 FRC Manual, Section 5.3.8
<R67> Teams may not use Innovation First Operator Interfaces from previous years' competitions.
Unread 10-01-2005, 21:08
jakk jakk is offline
Jonathan Kobayashi
FRC #0368 (Kika Mana)
jakk has a spectacular aura aboutjakk has a spectacular aura about
--->our team took a break in the 2004 competition. i just remember the old black controllers. the new ones seem to be alot looser than the the black ones.
Unread 10-01-2005, 23:37
We were discussing the Robot Controller -- the computer from IFI. It's still black. I suspect you're talking about joysticks. Yes, the ivory-colored right-hand-only joysticks aren't as "tight" as the older black ones. They don't return to center quite as strongly.
Unread 21-01-2005, 07:17
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
this years code/ last years controllers
Is it possible to load this years software into last years controllers? I want to test our camera out with last years robot ......
Thanks
Unread 21-01-2005, 07:34
Re: this years code/ last years controllers
http://www.chiefdelphi.com/forums/sh...troller+c ode
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
Open source Jeff_Rice Programming 16 25-03-2003 23:40
last years speed controllers..... archiver 2001 9 23-06-2002 23:44
